New Topic New Reply
Author: Subject: Coo!
posted on 29/3/08 at 04:53 PM Reply With Quote
Coo!
Got fed up with not driving the car since starting to fit bike carbs so I took it out for a quick whizz, even though I haven't got an air filter yet.
My, what a nice noise it makes now! there's a nice noise from the exhaust (much like before) but an even nicer loud noise from the induction roar.
Trouble is, there's no way I can drive it more than a mile or so without a filter, and without proper tuning...
Goes awfully quick, though!
Stuart_B
posted on 29/3/08 at 05:05 PM Reply With Quote
It moves and makes a good noise, i call that a result.
well done.
stuart
RazMan
posted on 29/3/08 at 05:35 PM Reply With Quote
That's the main thing I missed when I went over to fuel injection - induction ROAR
Raz
Guinness
Well done David,
The induction roar through bike carbs is brilliant IMHO!
Mike
locoR1
posted on 29/3/08 at 06:20 PM Reply With Quote
Nice one David!
That's the one thing i really miss on mine as soon as the turbo went on all that lovely induction noise disappeared
Even with the normally aspirated bike engine it never quite sounded the same as the old crossflow did on carbs
Check out my CB500T Cafe Racer build diary
posted on 29/3/08 at 06:32 PM Reply With Quote
Yup. Induction roar is good.... However, why does it happen with carbs and not throttle bodies? Is it because carbs are choked to create the venturi effect that carbs rely on... If it is then you're creating a vacuum by the engine sucking harder than the choked bit of the carb can flow. Which means you're strangling the air inlet.....
Noise = turbulence = lost BHP
Maybe
I realise some of the above is not true!!
New Topic New Reply
