New Topic New Reply
Author: Subject: Air filter material
posted on 7/4/08 at 08:35 AM Reply With Quote
Air filter material
Having failed to find a suitable air filter for my bike carbs I'm going to try to make my own (I've looked at K&N, Pipercross and ITG).
Does anyone know where I can get a sheet of good-quality air filter material suitable for use in a car?
I know about fish-tank filters, but I want something that's similar to pipercross's foam - several layers, with a fire-retardant layer facing the carbs.
It's all very frustrating, as the air filter is the last stage before I can take it for a tune-up!
worX
posted on 7/4/08 at 08:44 AM Reply With Quote
Depending on the size you want I may have some!
I bought a panel for a job and never used it...
I was keeping it for a rainy day, but if you want it, you can? what size do you need and I'll check my piece.
ditchlewis
posted on 7/4/08 at 09:04 AM Reply With Quote
I have a similar problem but due to space between the carb and the top chassis rail.
i am going to make a steel back plate for the carbs and then a glass fibre or steel air box with a cone filter on the widest end.
i take it that you did not go out for a drive on saturday, it was cold but fun.
ditch
[Edited on 7/4/08 by ditchlewis]
posted on 7/4/08 at 09:31 AM Reply With Quote
I'll need roughly 400mm x 250mm (maybe 300mm, not sure).
What sort of stuff is it?
[Edited on 7/4/08 by David Jenkins]
balidey
posted on 7/4/08 at 10:04 AM Reply With Quote
ITG make filters to custom sizes, and they may sell filter material, worth a call to ask them
worX
posted on 7/4/08 at 10:17 AM Reply With Quote
Just measured it David and it's a 300mm square piece of material, so not big enough I'm afraid!
It's air filter material that BigRich got for me from a motorbike shop local to him. I bought it to use for the airbox I made for PaulMW but in the end fitted a BMC Filter so didn't use it...
posted on 7/4/08 at 10:48 AM Reply With Quote
Shame - but it's a good lead on a possible source! Looks like I might visit a bike shop on Saturday! Or maybe have a look when I get to Detling...
snapper
Pipercross do 3 layer foam material in sheet form for £14 + VAT for 30cm x 60cm
You will need wire sheet to support it + you home made airbox
I eat to survive
I drink to forget
posted on 7/4/08 at 10:49 AM Reply With Quote
Ah - another good source!
UPDATE: communicated with Pipercross, confirmed that they have it in stock, and will be ordering some once I have confirmed the dimensions.
Thanks all!
balidey
posted on 7/4/08 at 11:55 AM Reply With Quote
Last time my dad got a custom made ITG filter delivered guess what packaging material they used to protect it in the box.........
will121
posted on 7/4/08 at 03:04 PM Reply With Quote
i made myself a airbox to the shape of the inside of the bonnet as didnt want to make another hole in the side of the bonet, there is a picture in my archive which is to big to post. the filter material is pipercross and came from www.gprdirect.com who sell it in sheets about 600x600mm
mistergrumpy
posted on 7/4/08 at 06:02 PM Reply With Quote
Here you go Will
[img][/img]
New Topic New Reply
