givemethebighammer
| posted on 25/5/08 at 05:34 PM |
motorbike stand M10 strength ?
I made a motorbike stand like the one in the picture today (used a bit more of my metal scraps up). I used a piece of M10 studing as the pivot that
threads through the swing arm pivot of the motorbike. It works fine only the M10 studding bent. The studing did come from B+Q so was possibly not high
tensile though. The question is, will high tensile studing bend as well, if so what material 10mm thick won't (I had thought that a piece of high
tensile rod with a M10 thread cut on the end of it might work). It can't be any more than 10mm as that's the inside diameter of the
motorbike pivot.
thanks
[Edited on 25/5/08 by givemethebighammer]
tegwin
| posted on 25/5/08 at 05:43 PM |
I always find studding is very bendy...
Can you not use a decent M10 Bolt? Should be a bit stiffer!
www.verticalhorizonsmedia.tv
matt_claydon
| posted on 25/5/08 at 05:44 PM |
I would expect 8.8 studding, if you can find it, should be fine. The stuff you get in hardware stores is really shi*e low grade. The 10mm rod with
threads cut at the ends is the best solution though. Or see if you can get an 8.8 or 12.9 bolt of a suitable length.
[Edited on 25/5/08 by matt_claydon]
907
| posted on 25/5/08 at 06:18 PM |
I made one of these stands for my Thunderace a few years back.
I used M16 studding, turned down on the end to fit the swing arm pivot.
(see pic)
hth
Paul G
stevec
| posted on 25/5/08 at 06:22 PM |
As said you can get higher tensile studding. The cheap stuff is just a collection of fractures waiting to happen.
Steve,
givemethebighammer
| posted on 25/5/08 at 06:32 PM |
cheers guys a few ideas there. I think the fastener place I use keeps high tensile studing. I'll try that first then think about other ways of
doing it.
givemethebighammer
| posted on 26/5/08 at 04:49 PM |
After a bit of a rethink, I redesigned it, the bike now pivots on two pieces of high tensile 10mm rod welded into some 19mm thick walled tube, which
slide in and out of some rhs. I added some M8 bolts to lock everything off. Works very well (used it to degrease my chain this afternoon. )
givemethebighammer
| posted on 26/5/08 at 04:51 PM |
other side
givemethebighammer
| posted on 26/5/08 at 04:52 PM |
in the air !
