K4000JB
| posted on 26/5/08 at 11:28 PM |
zetec in ron champions chassis
hi all im new to this forum and was wondering if anyone has already done the above conversion i need to know basically whether or not it will fit
thanks in advance
UncleFista
| posted on 27/5/08 at 12:07 AM |
It'll fit, but it's tight
  top view, hoses done
Tony Bond / UncleFista
speedyxjs
| posted on 27/5/08 at 05:54 AM |
Not as tight as a Jag engine
blakep82
| posted on 27/5/08 at 07:11 AM |
and the zetec will be quicker
________________________
Mole
| posted on 27/5/08 at 07:33 AM |
Yes mine fits just fine. Although the alternator needs some thinking and I think I'll need a remote oil filter.
big_wasa
| posted on 27/5/08 at 08:43 AM |
try and keep the engine low or you wont get any body work to fit
Mole
| posted on 27/5/08 at 10:18 AM |
I think mine might even be a touch lower than that.
big_wasa
| posted on 27/5/08 at 10:27 AM |
yeh mine needs to come down another 1/2"
SeaBass
| posted on 27/5/08 at 12:01 PM |
My blacktop just about fits...
Mix
| posted on 27/5/08 at 03:50 PM |
Hi
If your building your own chassis it will save a lot of 'fettling' if you make the sides an inch higher, (even if you just add an
additional rail to both sides welded to the top of the book rails), wonder how I came to that conclusion!
Regards Mick
K4000JB
| posted on 27/5/08 at 10:14 PM |
thanks chaps very helpful of you
speedyxjs
| posted on 28/5/08 at 02:02 PM |
Probably
scutter
| posted on 28/5/08 at 06:19 PM |
This is a blacktop in my new chassis, which has had an inch added in height from the 'H' tube by your knee to the front frame. The sump
sits 30mm below the chassis rails level with the bottom of the bellhousing.
[img][/img]
ATB Dan.
