New Topic New Reply
Author: Subject: need some turning
Miks15
posted on 11/7/08 at 09:22 PM Reply With Quote
need some turning
I need some steel bar turning down to make some adaptors for the transit drag link. Will need a bar about 40mm diameter with a 15mm hole through the center. It needs to be tapered if possible but if not i can do tht bit myself. I just dont have the bar and would take for ever to drill a 15mm hole thorugh it aswell.
If anyone can do this for me i can send exact dimensions required. cash waiting
Mikkel
blakep82
posted on 11/7/08 at 09:46 PM Reply With Quote
40mm diameter? seems quite big.. i know lolocost do some 25mm diameter for the transit drag link
________________________
Miks15
posted on 11/7/08 at 09:58 PM Reply With Quote
ye well it was a rough guess...
i need to get the piece which i can then fabricate into my uprights. So open to any suggestions.
will get in touch with lolocost
[Edited on 11/7/08 by Miks15]
blakep82
posted on 11/7/08 at 10:04 PM Reply With Quote
ooh, i mean this lolocost
http://www.lolocost.co.uk/ASPpages/part_details.asp?PartID=28
blakep82
posted on 11/7/08 at 10:06 PM Reply With Quote
no no no! ignore me...
i just realised what you mean.
like the sierra mushroom adapters, you mean...
Miks15
posted on 11/7/08 at 10:13 PM Reply With Quote
ye like the mushroom adapters but i dont need the outside to be properly machined to fit and everything. i see lolocost still do them but quite expensive for what it is.
i was hoping someone on here could just drill a hole in some bar for me, and if possible taper it on the lathe aswell. the bigger the piece the better really as that just gives me more to work with.
cheers
russbost
posted on 12/7/08 at 09:42 AM Reply With Quote
I have circular tapers made up for the Transit drag link end for the Furore, I think they cost me about £12ea + VAT, I'd have to check price but I can do them to you at cost +postage, can send pics/dimensions if you think this may be of any use.
Russ
welderman
might have some bar at work, will look on monday for you
Thank's, Joe
I don't stalk people
Nosbod
posted on 12/7/08 at 10:25 AM Reply With Quote
Mikkel,
Send me the drawing and ill sort them for you next week.
Chris.
New Topic New Reply
