finlay
posted on 22/7/08 at 07:50 PM |
anyone know where to get horn symbles/decals
hi all
i ve just re-wired my horn so it operates when i press my wiper button on siera stalks (with some help from Stuart g )
but i now need to find some decals or some sort of sticker to put on the wiper button to indicate that it now is the horn for SVA
anyone know where i can get some ?
cheers
mistergrumpy
posted on 22/7/08 at 07:56 PM |
Do you? As I was aware you don't even need a horn for SVA.
philw
posted on 22/7/08 at 08:01 PM |
If you must have one, just make something up with a Dymo label printer then take it off after
Must try harder
r1_pete
posted on 22/7/08 at 08:14 PM |
Vehicle wiring products do them Link
iank
posted on 22/7/08 at 08:16 PM |
You don't need any labels on the switches for SVA AFAIK, and strictly you don't need a horn - pretty stupid not to have one mind.
IVA is a different matter and they will both be needed.
The other thread has sources for the appropriate stickers if you want them.
Anonymous
posted on 22/7/08 at 08:34 PM |
I did the same as you and wired my horn to the Sierra washer push on the stalk. I bought a set of the labels R1-Pete suggests above from VWP and then
used some very fine wet and dry to remove the washer symbol from the stalk before applying the horn symbol. No problem at SVA (better to be safe than
sorry) and the label is still in place after 2k5 miles in all weathers.
BTW - I have had several occasions to use the horn to alert mong tin-top drivers to my presence ![](/images//smilies/wink.gif)
finlay
posted on 22/7/08 at 08:50 PM |
cheers gents
i just noticed i listed this twice
