New Topic New Reply
Author: Subject: Idea for storing wheel nut key?
posted on 6/8/08 at 08:23 AM Reply With Quote
I have fitted locking wheel nuts to save my lovely alloy from being pinched (ok, not mega expensive but still nice enough to be nicked) and need some idea of how/where to store the key.
It needs to be with the car and hidden somewhere non obvious.
Been thinking about drilling a hole in the key - it looks like a large nut - and iring it somewhere in the eninge bay.
Where and how do you keep yours?
posted on 6/8/08 at 08:27 AM Reply With Quote
Too big/heavy to keep on your keyring?
You'd always have it with you then.
AR-CoolC
posted on 6/8/08 at 08:29 AM Reply With Quote
Get one of those mega powerful little magnets and put it wherever you want?
Imagine what it would be like if there were no hypothetical situations.
iank
posted on 6/8/08 at 08:30 AM Reply With Quote
Wherever you store the wheelbrace?
Anonymous
clairetoo
posted on 6/8/08 at 08:40 AM Reply With Quote
Have your ear pierced and hang it there ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
posted on 6/8/08 at 08:50 AM Reply With Quote
1. too big for key ring
2. was considering the magnet but not sure if I trust that
3. wheel brace is in the garage, hmmm think I've seen the flaw here although AA man will have brace
4. no priecings or tattoos.
adithorp
posted on 6/8/08 at 09:12 AM Reply With Quote
I've got a customer who keeps it in the greenhouse because "nobody will look there"!!!
adrian
http://jpsc.org.uk/forum/
Howlor
posted on 6/8/08 at 09:30 AM Reply With Quote
How about you disguise it as something else. For instance can you make it into a gear knob so you just unscrew and use?
Or even drill it through and slot it over the gearstick as a collar. Bolt it somewhere on the engine so it looks as though it should be there.
907
posted on 6/8/08 at 09:45 AM Reply With Quote
I've been thinking about this.
I'm bu**ered from all directions.
Nowhere that a magnet will stick....
and I need a set of five
Paul G
balidey
posted on 6/8/08 at 09:50 AM Reply With Quote
my old peugeot 205 used to have a clip inside the glove box, just a wire clip that was attached to the top roof of the glove box, pulled it down, slip key on, the spring tension held it in place so it didn't rattle and was out of sight. Should be easy enough to make something up under your dash
posted on 6/8/08 at 10:28 AM Reply With Quote
What about a single clip from one of those socket set bars. You could rivet it to the bulkhead or up under the dash and just snap the security key onto it.
posted on 6/8/08 at 10:36 AM Reply With Quote
Fit a "Key safe" somewhere hidden from view
http://www.easylinkuk.co.uk/page65.html Rescued attachment wp0b708a24.png
Stuart_B
posted on 6/8/08 at 10:41 AM Reply With Quote
i am going to leave mine at home with the spare wheel. Lol
stuart
McLannahan
posted on 6/8/08 at 12:20 PM Reply With Quote
I had mine in a small plastic casing stored under the dash. Case has drilled through the back and zip-tied in position.
Danozeman
posted on 6/8/08 at 02:09 PM Reply With Quote
Put a box under the bonnet somewhere or clip it up behind the dash if you can get up there.
Dan
New Topic New Reply
