New Topic New Reply
Author: Subject: Cooling system questioin
TOO BADD
posted on 9/8/08 at 06:07 PM Reply With Quote
Would you need an overflow pipe from the header tank in a sealed system using a standard type rad cap on the tank ?
Thanks for any replies
indykid
posted on 9/8/08 at 06:16 PM Reply With Quote
no
tom
TOO BADD
posted on 9/8/08 at 06:31 PM Reply With Quote
Thanks, will learn to spell next time !
posted on 9/8/08 at 06:43 PM Reply With Quote
You don't need it but generally speaking a good idea saves potential mess in the engine bay + stops the electronics getting sprayed if the engine boils.
posted on 9/8/08 at 07:27 PM Reply With Quote
hmmm, maybe i am misunderstanding the question of the response but if you do that, then it will no longer be a sealed system,
the expasnion tank souod be about 1/2 full when cold and large enough to hold the water when it expands when hot.
TOO BADD
posted on 9/8/08 at 07:38 PM Reply With Quote
Interesting replies.......
the reason for the question is .. I have a low water sender in the tank but if I fill to half level it seems to spit a little out to the level sender and keeps flashing my warning light. never empties out but just keeps to this level.
A bit annoying to get a bright red light flashing at you. Thought of blocking the overflow to overcome
adithorp
posted on 9/8/08 at 08:05 PM Reply With Quote
Sounds to me like the presure cap is knackered. Level should only increase slightly when hot. If the level is coming up enough for to push water out then the cap is duff. It should only release presure when when there's a problem.
adrian
http://jpsc.org.uk/forum/
TOO BADD
posted on 9/8/08 at 08:06 PM Reply With Quote
brand new cap !
indykid
posted on 9/8/08 at 09:07 PM Reply With Quote
hmmm, just reread the OP and i notice you say it has a standard type rad cap.
i assumed with you saying it was a sealed system that it'd have a plastic header tank screw cap and thus no provision for an overflow connection.
can we have a picture of your system just to confirm the specifics? if it is a sealed system, the small top pipe will be a breather to let air escape from the engine into the tank, not an overflow.
tom
posted on 10/8/08 at 02:55 PM Reply With Quote
If the engine boils no amount of airspace would be enough --- I can't remember the exact figure but as steam water has about 2000 times the volume it has as liquid water.
New Topic New Reply
