Slater
| posted on 20/8/08 at 08:57 AM |
CVH Alt mount on a zetec
This is my CVH donor alt mount, it's a beast!. The mounting holes fit my zetec but it puts the CVH altenator 15mm too far forward. Can I attack
it with an angle grinder and remove 15mm of material from the front bottom corner (as shown), then use washers to make up the 15mm at the back? Any
problems with this?
Also, I'd like to remove some of the surplas material as it seems to be a little over engineered, just not sure how much to remove. Anyone done
this before?
Keith
[img][/img]
tootall
| posted on 20/8/08 at 09:30 AM |
hi ive done a zetec conversion to my old XR3i when i was a boy and i did a zetec turbo conversion in my friends escort rs turbo last month the
alternator mount was quater the size of that look for a mk4/3 escort cvh alternator mount. might even have one in workshop.
[Edited on 20/8/08 by tootall]
some people dream of sucsess, others just get on and do it !!
paulf
| posted on 20/8/08 at 09:35 AM |
I made an alternator mount for mine using 5mm plate, that cast item is far to heavy and probably will put the alternator in a position where it fouls
the inlet manfold or steering down link.Best to look for a small alternator and fab a bracket to suit.
Paul
big_wasa
| posted on 20/8/08 at 03:17 PM |
way to much scrap metal there
whitestu
| posted on 20/8/08 at 03:51 PM |
I made one as well - dead easy, and miles lighter.
Stu
scotty g
| posted on 21/8/08 at 04:57 PM |
I chopped the top off the Zetec alternator mount and used that to fit a CVH alternator onto the Zetec, lines up a treat, just on the other side is
all.
scotty g
| posted on 21/8/08 at 05:10 PM |
the faint line shows where i cut it, sure its a bit heavier than making one but it was free with the engine and i'm a big fan of LOcost!
