chris_smith
posted on 12/10/08 at 04:39 PM |
bit of progress
not sure if this is in the right section as there isnt a specific Locost forum
anyway did a bit of work on the front brake lines last week only just got the pics
can anyone see any obvious problems?
eznfrank
posted on 12/10/08 at 04:43 PM |
How tight are those p-clips? They look quite big but might just be the photo.
What's the spacing <20cms?
And in photo 6 how close is it to the column? Again could just be the photo but looks pretty close.
chris_smith
posted on 12/10/08 at 05:23 PM |
p clips are 4mm just about gripping but no movement when trying to move the pipe, think i worked on about 150mm for spacing certainly less than200mm
photo 6 is an optical illusion photo 7 shows its not as close as first looks
thanks
[Edited on 12/10/08 by chris_smith]
designer
posted on 12/10/08 at 07:28 PM |
It is best to space P clips for pipework every 8in.
chris_smith
posted on 12/10/08 at 08:00 PM |
whats the reasoning for this?
posted on 12/10/08 at 08:17 PM |
Have a look at the spacing on a Ford Focus for example , at least 18" between clips .
Think you may have a leak from the master cylinder connections.
