New Topic New Reply
Author: Subject: Tightening ball joints
vintagebuilder
posted on 12/1/04 at 06:40 PM Reply With Quote
Evening All,
Sorry if this has been covered previously.
I've just fitted the upper ball joints to my Indy front suspension. When I attempt to tighten the nut inside the "mushroom insert" the threaded part of the ball joint revolves
. Could anyone please let me know how to tighten up the nut. Thanks.
Mk-Ninja
posted on 12/1/04 at 06:44 PM Reply With Quote
You need to hold it in tightly so that the taper stops it going round, it usualy works if you give it a tap with a rubber mallet.
HTH Gordon
I'm sure I've got one, just don't know where I've put it
Mk-Ninja
posted on 12/1/04 at 06:46 PM Reply With Quote
Oh dont forget your locknuts onto the upper wishbone. I did.
Gordon
posted on 12/1/04 at 07:49 PM Reply With Quote
Failing that you could file a slot in the top and lock it with a screwdriver if you can still get a ring spanner on to tighten it up.
yours, Pete.
vintagebuilder
posted on 12/1/04 at 07:55 PM Reply With Quote
Thanks for the help. 2 taps with the rubber mallet worked a treat.
New Topic New Reply
