locoboy
posted on 13/1/04 at 12:30 PM |
Paint damage
Hi all,
I am nearing the end of my donor parts clean up and am now concerned that when i put my nice new shiny front up rights onto the balljoints and torque
up to the correct spec the nut will just peel off/ crack the paint around it.
Are there any tried and tested ways to avoid this, im sure this problem has the potential to rear its head in many other areas too, rear uprights,
caliper bolts etc.
i dont want me time and effort ruined becasue of this if it is avoidable
Locoboy
posted on 13/1/04 at 01:32 PM |
i think if the paint was on a well prepared surface (etched etc) then it shouldnt come off? maybe sand it thin where the nut will go and touch it up
afterwards?
posted on 13/1/04 at 01:38 PM |
Col,
I've found this problem as well and not found a good solution yet either. I spent a quiet moment F'ing & Flinding at the chipped
paint on my wishbone brackets when I fitted the wishbones.
In the end I think you just have to get on with it and accept that some paint damage is unavoidable.
Anyone else got any suggestions???
Nick
mackie
posted on 13/1/04 at 01:59 PM |
Washers made of fluff?
locoboy
posted on 13/1/04 at 02:44 PM |
i thought about maybe 2 washers under the nut with thin oil between them hopefully the lower surface of the bottom one will stay put on the (for
example) upright and the top surface of the top one will stay in contact with the bottom of the nut leaving the two connecting faces of the washers to
slide on each other.
Dont know if it will work but it may be better than just cranking up the nut and screwing up the nice paintwork.
Or........ just thought if this one, Mask the paint fit the nuts, and trim with a stanley knife trying only to cut the masking tape, leaving tape
under the nut?
Workable or not?
Locoboy
kingr
posted on 13/1/04 at 03:11 PM |
Ummmm, maybe I'm missing something, but what's wrong with just using a single washer?
Kingr
Mix
posted on 13/1/04 at 03:40 PM |
Yep !!
Have to agree with Kingr, a single washer with a bit of lube between the nut and the washer. Oh! and if you study the washer you will see that it has
normally been produced by stamping from sheet and as such one surface will have sharp edges and the other slightly rounded, assemble with the rounded
side against the nut.
Mick
DaveFJ
posted on 13/1/04 at 04:08 PM |
quote: Originally posted by Mix
Yep !!
Mick
ERRR - NO
assemble with rounded side against chassis....
Dave
posted on 13/1/04 at 04:11 PM |
Rubber spanners.
Live with it, it's going to happen anyway. Keep some paint for touching up after you've done scratching it.
Mix
posted on 13/1/04 at 04:40 PM |
Washers
If you assemble the washer with the rough side against the nut then the washer will probably spin with the nut as you tighten it, this may cause any
finish to lift.
If you assemble the washer with it's smooth side against the nut the chances are that the washer will remain fixed in respect of the nut and
therefore not cause so much damage to the finish.
But then again it's up to you.
Mick
There is also the option of 'wet assembly' whereby the final assembly is carried out before the surface finish, (in this case paint) is
dry.
[Edited on 13/1/04 by Mix]
MikeR
posted on 13/1/04 at 04:56 PM |
I read a thing a while ago about torque and lubricant. Basically all torque figures are given when the thread doesn't have lube. Just wondering
if lubing up the washer would affect the torque .....
DaveFJ
posted on 13/1/04 at 05:01 PM |
I see your point Mix BUT
if sharp edges are toward nut they MAY make the washer rotate at final tightening which would mena the nice smooth surface would rub against your
paint and probably not mark it
However if you do it your way the washer WILL cut into the paint and damage the surface no matter what you do........
Dave
Mix
posted on 13/1/04 at 05:23 PM |
Washers
The degree of 'roughness' I am refering to is probably less than the thickness of a painted surface and hence I feel it is better to
'lock' the washer to the surface thus reducing the tendancy for it to tear the surface which would be the case if it rotated.
I suppose the jury's out on this one.
Mick
GO
posted on 13/1/04 at 05:37 PM |
MikeR, you beat me too it.
I'm no pro on these things but thats what I'd heard, that any form of lube will affect the torque settings and you're (I think)
likely to over tighten it. By how much I've no idea, and probably depends on the kind of lube used. KY will probably have the biggest effect...
posted on 13/1/04 at 08:35 PM |
I was taught that you don't lube what you don't want to disassemble often. So stuff like wheelnuts get copaslip, rest stays dry. Just my
theory though.
yours, Pete.
flyingkiwi
posted on 14/1/04 at 02:13 PM |
having spent the last two days beating the poo out of an aircraft trying to remove a bolt that some plank has forgotten to grease I would go with a
small amount of lube on the thread, it shouldn't affect the run down torque too much and if you ever have to take the part off again (maybe
refishining paint that's been chipped off by stones????) it will make it a lot easier, nothing worse than having a seized nut to split!
But that's just what I'm gonna do!
chris
It Runs!!!!! Bring on the SVA!
mackie
posted on 14/1/04 at 02:29 PM |
I was changing my brake disks the other day and one of the little retaining screws was rusted in and seemingly made from putty-grade steel, the
screwdriver neatly ripped off the philips pattern head with little effort. So I drilled it. Pain in the ass and should have been coppaslipped.
Mk-Ninja
posted on 14/1/04 at 03:08 PM |
Im with Pete, to the point that you should realy use nylocs or thread lock on the bits you dont want to come loose.
Gordon
I'm sure I've got one, just don't know where I've put it
Mix
posted on 14/1/04 at 04:19 PM |
Lube during assembly
Lubing a thread and then torquing to a specific 'dry' value will result in more tensile load on the fastener than intended.
However there are obvious advantages to lubing threads.
One way to achieve the correct tensile load and lube the thread is to first torque the fastener 'dry', mark it's position, (witness
mark), disassemble it, lube it and reassemble to the witness marks.
This proceedure should only be used for fasteners with positive locking such as split pins as lubing the thread will also make the fastener more
likely to lose torque with vibration etc.
Should this not be an option then bolts should still be lubed to aid disassembly / prevent corrosion but the lube should be kept away from the portion
of the thread in contact with the nut.
Mick
