Author: Subject: could you post some pics of your rear
MK chippy
posted on 27/10/08 at 09:50 PM Reply With Quote
BRAKES!!!
Looking to fit my rear sierra calipers to my indy but cant really see how it all goes together?! Think im missing a mounting bracket or something? Pictures would be good.
Dave
eznfrank
posted on 27/10/08 at 09:53 PM Reply With Quote
Just bolt straight onto the rear hubs?? Did you spec calipers when you ordered?
blakep82
posted on 27/10/08 at 10:01 PM Reply With Quote
i don't know the answer, i'm wondering if maybe some more info on back axles etc might help those in the know?
________________________
MK chippy
posted on 27/10/08 at 10:07 PM Reply With Quote
ah thought so. think i'll be ringing MK tomorrow then.
eznfrank
posted on 27/10/08 at 10:21 PM Reply With Quote
The bracket is part of the rear hub carrier. It has 2 lugs on it that they attach straight on to.
tootall
posted on 27/10/08 at 10:34 PM Reply With Quote
dont forget they also fit the left on the right and right on the left due to the handbrake cable coming out at the bottom they swap it so cable comes out the top! so when bleeding u need to take caliper off and turn so bleed nipple is at top put a block of wood between pads or the disk so u dont have to wind the piston back again.
some people dream of sucsess, others just get on and do it !!
matt.c
posted on 27/10/08 at 10:49 PM Reply With Quote
[img][/img]
cryoman1965
posted on 27/10/08 at 11:11 PM Reply With Quote
I don't think asking for pictures of peoples rears is appropriate for this site.
You need to visit yuvutu.
N
mad-butcher
posted on 28/10/08 at 07:52 AM Reply With Quote
There are 2 types of rear upright 1 for disc 1 for drum.from memory the drum type are standard you have to specify disc.
looking at the upright head on if it is drum you will have 2 holes at the top and 2 at the bottom and the damper mount wil be the full width. if it's disc the 4 holes will be turned about 45deg and part of the damper mount will be missing.
if you post a photo some-one can tell you immediately
tony
Gergely
posted on 28/10/08 at 08:42 AM Reply With Quote
