Hey guys
I'm looking for hub adaptors that will convert from a 4x100 hub to a 4x108 bolt pattern. I've found loads that do it the other way around
but none that will do it the way I want.
I'm also looking for something within an acceptable price range, Venom will do it but for a pair it would be well over £200, no thanks.
-Josh
why not get the hubs re drilled?
Unless you need the thickness of the spacer
The hubs are too thin to redrill.
Try these people.
I ordered some today for less than £80 a pair delivered.
They make to order.
Tony
Originally posted by tony.g
Try these people.
They make to order.
Tony
Try these people.
They make to order.
Tony
I use them all the time![]()
Spot on! Thankyou.
How thick do they need to be? I should be able to help out and less than £70 a pair
