Since I have at least one dead instrument in my donor car's instrument cluster, I am considering aftermarket options. However, I have a
cable-driven speedometer at the moment. What are my options for an aftermarket speedometer? Are there adapters that can clip onto the rotating cable,
or do I just remove that and use a magnet-based system? If I go for magnets, I'm thinking of putting it on the diff input coupling, and
fabricating a bracket to hold the sensor. Does this sound about right?
In my MK Indy I ditched the Sierra instruments and fitted a magnet/sensor based speedo. As you suggest, I glued the magnets to the diff input flange
and made a rivet on bracket to hold the sensor. It worked fine and passed IVA no problems.
Glad I did it as the Sierra cable from the gearbox would have been a nightmare to deal with.
I'm using a hall effect sensor for my racetech dash 2. Mounted to a bracket to read off the prop shaft bolts.
Cheers folks, looks like I was on the right track at least.
Another vote for a magnet on the prop / dif area.
Dead easy to calibrate for IVA and should you ever change wheels / tyres then easy to re-calibrate.
Paul G
I changed from a cable setup to the magnet/pick up sensor with an etb dd2. It's infinitely programmable for gearing etc and very easy to set up(I
did it so it can't be difficulty! ) mine in glued to the driveshaft out put flange. Made a bracket from 4mm steel bolted to a diff case bolt.
The Mk2 uses an electronic speed sensor which bolts onto the Mk1 gearbox in place of the cable.
I used one on my Mk1 based Haynes Roadster to drive my speedo:
[Edited on 22/12/15 by skov]
Originally posted by micksalt
Since I have at least one dead instrument in my donor car's instrument cluster, I am considering aftermarket options. However, I have a cable-driven speedometer at the moment. What are my options for an aftermarket speedometer? Are there adapters that can clip onto the rotating cable, or do I just remove that and use a magnet-based system? If I go for magnets, I'm thinking of putting it on the diff input coupling, and fabricating a bracket to hold the sensor. Does this sound about right?
Cheers![]()
NA mx5 is cable, NB is electric, though exactly what the signal shape is like and whether its compatible with aftermarket gauges is not something I can comment on. Is it an neccesity to change to aftermarket gauges or are you simply after a different look? Revlimiter does a range of alternative gauge faces if you want ot 'dress up' your gauge pod
Originally posted by jim87
Skov ,
what instruments was this with ? I've been looking at using one of these, but had read that the mk2 sensor doesn't output digital pulses that most gauges would expect
Jim
Originally posted by chillis Is it an neccesity to change to aftermarket gauges or are you simply after a different look?
Cheers skov - that could be very useful!
Mick, if all you need is the fuel guage, then you're welcome to have the old one off my mx5 cluster
