Hi collective were is the cheapest place to get a hans device
What angle do you want? 20deg is much cheaper than 30deg.
Have a look at Plays Kool
http://www.plays-kool.co.uk/acatalog/Hans-Devices---Accessories.html
Bought mine from Ed Moore cost me £245 for a 20degree model hans......
Hi
If I had a group buy of 10 I could do them at £235 with free delivery
Thanks Danny
I would be number one of ten
I may be number 2 if I can get a 20 degree one to work, need to borrow one first.
I would consider one.
At the NEC this weekend so will try a few sizes on.
What's everyone doing about belts? Do we need HANS approved ones? If so any offers on Danny?
Mark.
You don't need hans specific belts to use a hans.but if you do use hans specific belts then you MUST wear a hans!
You beat me to it Dan. So many people are getting confused about this rule and it is quite simple really. Just use the 3" ones you have and dont be conned into buying 2" HANS belts, because if you leave the hans at home, thats where you will be going. I and others still use our 3" belts and in my case with a 20 degree in my single seater. Works a treat and cheap.
I need one for next year, £235 sounds good if you can make the numbers
In most situations people need a 20 Deg Medium HANS. 30 Deg is really for formula cars and Large is 18" neck or bigger.
So 20 Deg Medium using your existing, in date, 3" harness is the cheapest way to do it. You will also need to make sure your Helmet is approved
for use with FHR.
I'd be in as well for a group buy.
How many is that? 6?
I could also be in for this too....
Just a few points for anyone looking to buy a HANS/FHR.
1. If you wear one the belts need to be racing tight, as in almost can't breath tight.
2. Side vision is quite restricted as you can't easily rotate your head.
3. You need a current spec car racing helmet with posts already fitted to ensure the HANS will work.
4. HANS tends to be uncomfortable to wear for long periods and can cause issues getting out of vehicles (tends to catch the rear of the yoke).
5. Currently the MSA does not require FHR/HANS for Road Going cars in Sprinting.
6. You need a 4 belt harness minimum (ideally 6) which has been fitted in accordance with HANS/FHR spec. The rear belts must be level with your
shoulders or slightly below. If the belt mounts are above your shoulders HANS will not work.
7. HANS offers no side impact protection at all, it is a Front Head Restraint after all.
So if you are looking to buy and use one please make sure your belts are suitable and correctly fitted and that your helmet is to the correct
specification.
6. You need a 4 belt harness minimum (ideally 6) which has been fitted in accordance with HANS/FHR spec. The rear belts must be level with your shoulders or slightly below. If the belt mounts are above your shoulders HANS will not work.
So if you are looking to buy and use one please make sure your belts are suitable and correctly fitted and that your helmet is to the correct specification.
Yes, they will be fine assuming they are fitted as per the HANS instructions.
http://www.msar.co.uk/pdf/HansUSAOwnersManual.pdf
Read and digest, especially the belt fitment.
[Edited on 12/11/15 by jeffw]
thanks
Other than the belts being quite long (its a clio and they attached under the cage) I should be fine.
[Edited on 12/11/15 by Norfolkluegojnr]
If they are long you may need to cross them behind the seat to get the correct angle. Long belts obviously stretch more than short belts (1 inch per foot rings a bell for some reason) in an accident and can allow the HANS to lift off the shoulders.
I am in the market for a 20 degree hans device , I really wanted to get one after Christmas but if there is bulk purchase discount available somewhere then i`m in
I'd be in for one on a bulk buy :-)
I've been using a Stand21 20 Degree Medium for a few seasons, but now looks like I'll need an adjustable one - so happy to move it on if anyone wants it.
I'd be in for one too.
Wyn
To my count there is 7 people who are interested in the Hans.so we only need 3 more to get the bulk buy.
If those who are interested could send me a U2u with there name and contact number.i will contact you ASAP
Thanks Danny
Stand 21 Club hans Device FIA Approved 20° recline (Med/Large) Race Rally Track
http://www.vulcanracing.co.uk/apps/webstore/products/show/5635823
£233ea ,,,, not asked for multi buy discount yet
Try this place http://www.rr-ni.com and speak with Raymond is very keen on price, I'm in the process of buying a new helmet from him
Speak to Peter Birthill he does them around 230
I got mine from him top guy
he is on Facebook
link
Danny's multi buy sounds good,
Are they SCHROTH with sliding tether's Danny.
Let's not forget the free delivery chaps.
A mate of mine is putting an order in soon, but wants to get upto 20 orders. Think he's up to 12 or so.
arround £204 inc vat Schroth super sport. Might be a bit of postage or collect from Lancaster Area.
See Link, don't contact me.
http://www.britishrally.co.uk/classifieds_view.php?id=19041
Demon tweaks, under £200 this week
http://www.demon-tweeks.co.uk/motorsport/fhr-hans-devices/hans-sport-ii-hans-device
Or the super sport
http://www.demon-tweeks.co.uk/motorsport/fhr-hans-devices/schroth-protec-super-sport-fhr-hans-device
[Edited on 25/11/15 by mark chandler]
That's plus vat mark!
I'm going for one of these:
http://www.jjcraceandrally.com/race/hans-devices/simpson-hybrid-sport-head-neck-restraint
Certainly not cheap but its' not angle dependant so I can use it in any car and it also works in offset and side impacts and you can turn your
head more easily.
I need one too but I'm significantly more probe than 20deg.
Certainly not cheap but its' not angle dependant so I can use it in any car and it also works in offset and side impacts and you can turn your head more easily.
This is the one I have. I sold a HANS to get it.
I'd hold back for now Callan.
I was told today that the msa are looking into those hybrids after some nasty incidents
[Edited on 25/11/15 by daniel mason]
Any feedback? It looks like what I want (and I already have a Simpson Helmet) but is it worth the £500+ Would be interested to hear what you think before I fork out.
