Starter Identification
alland3851 - 9/6/16 at 04:23 PM
Hi, I have a starter from a 1983 Sierra on a 2.0l pinto attached to a 5 speed box. The starter is duff and needs replacing. I can't find any identification on it, so i have a problem trying to get a replacement. The dimensions are Total Length - 9ins Body and Mating Surface 3 1/2 ins 10 Tooth drive . The solenoid sits approximately on top.
Pics are in my archive
Any help appreciated
Thanks guys
[Edited on 9/6/16 by alland3851]
avagolen - 9/6/16 at 06:08 PM
Not sure if it is the same, but these are of a 1.8CVH starter motor.
alland3851 - 9/6/16 at 08:02 PM
Thanks avagolen, looks similar but not the same. Doubt it would fit but I would love to be proved wrong.
starterman - 15/7/16 at 07:47 PM
Which side of the engine is it fitted?
You probably need an LRS110
alland3851 - 15/7/16 at 08:46 PM
Thanks for the info Straterman. Ended up getting new one to fit. Starting problems now solved.
