Can anyone tell me the correct name of this part? Ive searched for shell connector but cant find much info about it so presume its called something
else?
N1
https://www.ebay.co.uk/itm/GX16-Aviation-Plug-Male-Female-Metal-Wire-Panel-Connector-2-3-4-5-6-8-9-Pin-16mm-/372040618103?var=&ul_ref=http%3A%2F%2 Frover.ebay.com%2Frover%2F1%2F710-53481-19255-0%2F1%3Futm_source%3Dtwenga%26utm_param%3DeyJlcyI6MCwicyI6OTcyMDIzNywiY2kiOiIwMzEyMzZjOWExNTI5MTYzYTEyYW EwNTMxOWQzY2ZkMiIsImkiOiI1OTc2NzA4ODE2ODc2NDY1MTcxIiwidHMiOjE1NDA0MDA5MjYsInYiOjMsInNvIjoxNTAwLCJjIjoxODE4Nzd9%26utm_campaign%3Dtwenga%26utm_medium%3D cpc%26ff3%3D4%26pub%3D5574631662%26toolid%3D10001%26campid%3D5338353462%26customid%3D031236c9a1529163a12aa05319d3cfd2%26mpre%3Dhttp%253A%252F%252Fwww. ebay.co.uk%252Fitm%252FGX16-Aviation-Plug-Male-Female-Metal-Wire-Panel-Connector-2-3-4-5-6-8-9-Pin-16mm-%252F372040618103%253Fvar%253D%26srcrot%3D710- 53481-19255-0%26rvr_id%3D1715768031509%26rvr_ts%3Da70cd4691660abc33073d164ffff55b4&ul_noapp=true&redirect=mobile
Aviation connector
looks very like the connector for CB (&ham) microphones
https://www.amazon.com/PIN-PANEL-MOUNT-MICROPHONE-CONNECTOR/dp/B00H579TXU
typically called 4 pin Din, also available in anything from 2 to 13 pin,... not suitable for high current or high voltage,...
Originally posted by number-1
Can anyone tell me the correct name of this part? Ive searched for shell connector but cant find much info about it so presume its called something else?
N1
Cheers for the replies lads
Its for push button gear changes. The buttons are on a steering wheel. Its going to connect to the cable so the steering wheel can be removed as
needed
quote:in that case its very likely you could/should also use the nice coily cable from the microphones that I referred to earlier.
Its for push button gear changes. The buttons are on a steering wheel. Its going to connect to the cable so the steering wheel can be removed as needed
https://www.amazon.co.uk/Maplin-Audio-Locking-Connector-Socket/dp/B005XK8ZDQ
