My next big motering dilemma....
After driving my alfa 156 for around 2 years I'm looking for something a bit different. In doing so, I stumbled upon a TVR 3000M. Would I be
absolutely mad to run this as a daily driver? My daily commute is around 35 miles round trip. The car would need to live outside *all the time* since
the Indy occupies the garage...
My guess is that it will be, erm, challenging at best but loads of fun.
Anyone clued up on these cars and their reliability? (mind you, I'm used to a 10 year old Alfa ;-))
I reckon it'll be fine
It's quite old, but hopefully all fixed by now.
As for keeping it outside, get a 2 post car lift and keep the Indy "in the air" when not in use.
Simon
I know they have a terrible reputation for reliability but as above, problems may be ironed out by now
Originally posted by speedyxjs
I know they have a terrible reputation for reliability but as above, problems may be ironed out by now![]()
Originally posted by sebastiaan
Were they unreliable because of the electrics (easy to fix) or mechanically (probably a bit harder to fix)?
OK, thanks for the info. So, apart from ome electrical gremlins, is there anything else to look out for?
my dad used one for years as a daily drive, through snow and everything, the electrics on his are okay, the engine can be a bi*ch to start on colder
days, but mostly starts first time....
go for it id say, theyre beautiful cars!!
My only memory is of one causing an accident trying to keep up with my Alfasud years ago.
I don't think they are very good at all around the corners.
As a result I think I'm biased and would keep well clear.
Stu
I keep my elsie outside which, whilst the rep isn't as bad as TVR, Lotus aren't known for their german-like build quality.
The reliability problems with cars like the Elise and the 3000M are more associated with leavung the car standing (and therefor eseizing up and
flattened battery) and the same issues you'd get if you left any other car unused for any length of time.
You'd struggle to find many to recommend a 156 as a daily driver so how bad can a TVR be?
adrian
ps. I had a 156 v6 for 2 years. Loved it but got rid before anything major went wrong!
personally, i wouldnt. Youve got a "fun" car, use that more often if you want a bit of fun?
