Nissan Navara D22 fault code
LoMoss - 25/11/08 at 08:40 PM
Hi
Then engine management light comes on after a couple minutes. Have managed to get the fault code 0087 ECM 14. But cannot find what this relates to. Any suggestions are welcome. Would like to avoid a trip to the main dealer.
Hall
Volvorsport - 25/11/08 at 08:45 PM
search generic OBD DTC codes - at least itll give you a clue .
locoboy - 25/11/08 at 09:49 PM
Probably means the crank is about to fall out.
Thats what happens to most of them!
LoMoss - 25/11/08 at 10:03 PM
found this; p0087 Fuel Rail/System Pressure - Too Low. Cant find a reference to ECM 14. What can cause that after running for a few minutes (only when driven)
Just waiting for the crank to give up, its apparently the big end bolts that fail.
DRC INDY 7 - 25/11/08 at 10:03 PM
p0087 fuel rail/system pressure too low
DRC INDY 7 - 25/11/08 at 10:08 PM
fuel pump or m prop valve or fuel rail pressure sensor fault
[Edited on 11/25/2008 by DRC INDY 7]
iceman26 - 25/11/08 at 11:53 PM
this code can come on due to fuel filter getting blocked
