killing demented cars
Mr Whippy - 18/12/08 at 02:36 PM
I was just reading about an Arial Atom that went wild and the driver being forced to drive it into a wall at great speed to stop it, apparently the throttle opening by its self. I’ve always been wary about the concept of flyby wire throttles and certainly have heard of plenty of cases that cars have taken off on their own, the drivers fighting, usually in vain to bring them to a stop. I’ve even driven (quite happily as it happens) with jammed open throttles down the dual carriageway in the past due to carb icing so its not just all singing modern engines that can go wrong.
I wonder how many builders here have an engine cut button on the dash (say cuts the coil supply) for such occasions, my buggy has a simple switch for the ignition and I think I’ll be doing the same for the Bluebird when I fit the cruise control incase it goes mad…
oh and if you haven't seen it -
[Edited on 18/12/08 by Mr Whippy]
cd.thomson - 18/12/08 at 02:40 PM
I have an emergency way to stop my cars in all situations.
In the case of the throttle sticking open I'd use my "emergency" gear stick to put the car into "emergency" neutral. Then hit the "emergency foot brake" to slow the car down. No need for a wall, although the engine may rev itself to death it wont kill me
tomgregory2000 - 18/12/08 at 02:44 PM
i put in neutral and use that thing called a "KEY" to turn it off
Stott - 18/12/08 at 02:44 PM
I have one that cuts fuel, coils, DBW throttle and all that jazz, operated by a key, in the ignition barrel, quite effective
RE the atom, Surely you'd just switch it off, dip the clutch, pull it into neutral, anything apart from bin it.
PS don't think an atom is DBW but cabled as in the EP3 civic type r
Mr Whippy - 18/12/08 at 02:45 PM
well apparently he tried this too, and it didn't work
I actually remember a BMW owner who this happened to and who did a summersalt over a roundabout, when asked why he hadn't just switch the engine off he replied he wasn't sure if the steering lock would come on
DarrenW - 18/12/08 at 02:46 PM
If you are driving along the road and use such an ignition switch isnt it possible for the engine to continue running?
Knocking out of gear sounds feasible but i guess its all in the timing, i dont think the chap in the atom had an awful lot of it iirc.
liam.mccaffrey - 18/12/08 at 02:46 PM
I have a cut-off switch
coozer - 18/12/08 at 02:47 PM
Thats right, throttle sticks wide open so you have the clutch to stop the car moving, the brake to push when you've applied the clutch, the gearstick to put into nuetral or first then of course the key to turn the engine off.
02GF74 - 18/12/08 at 02:51 PM
hmmmm, there have been stories about electronickery going haywire; most have been excuses for BMW drivers to check out their top speed on the M1.
what are the odds he was doing the same, crashed and is seeking to blame the manufacturer?
does it not have a clutch or brakes fitted?
Mr Whippy - 18/12/08 at 02:56 PM
out of curiosity
does the steering lock come on when the igntion is turned off? On say a ford, I don't remember turning it two clicks
DavidM - 18/12/08 at 03:06 PM
The steering lock doesn't usually come on until you take the key out.
cd.thomson - 18/12/08 at 03:17 PM
In my 04 fiesta i have 1st click for steering lock and ancillaries, 2nd click starts everything else and 3rd movement turns the engine over. Therefore taking the key back 1 click while the engine is running will cut the engine but will not affect the steering lock (or radio, if you're listening to something particularly inspiring while trying to prevent a nasty car accident).
hughpinder - 18/12/08 at 03:19 PM
Don't forget that if you turn the engine off you immediately loose the power assistance on your steering, and probably the vacuum that helps your brake servo too, so be careful - its not just the steering lock you have to think about! Just dip the clutch and use the brakes!
A friend of mine who was a mechanic for mercedes took a S500 for a 'test' after he'd fixed it , and the throttle stuck fully open at about 90 - He turned the ignition off. Lets just says that you have to be careful to just turn the key to OFF and not the position where the steering lock is on. He still recons he was incredibly lucky not to crash between steering lock on and back to off.
Hugh
vinny1275 - 18/12/08 at 03:22 PM
Likewise to most of the replies above. Unless he convinced Ariel to build him an Auto, he should have been able to stop it by using the clutch. maybe he just panicked - an odd reaction to deliberately drive into a wall though. More likely he binned it then thought up the excuse after.
Mine's going to have a cut-out, and it has an electric fuel pump as well - turning the ignition key off should cut the coil and the pump, so you've got no sparks or fuel to keep the engine running.....
BenB - 18/12/08 at 03:29 PM
Are there some cars out there where the engine doesn't stop when you switch off the ignition???? I'm confused!!!
Clutch down, bang it into neutral, switch off engine, use middle pedal to stop.
Or is that too complicated?
MikeRJ - 18/12/08 at 03:31 PM
You don't immediately lose servo assistance for the brakes, it takes several presses of the pedal to lose all the stored vacuum in the servo.
Also if you are travelling at reasonable speed, loss of power steering isn't such a big problem (though it certainly gets noticeably heavier), if it fails when you are only doing a few mph it can take a herculean effort to turn the wheel on a heavy modern car.
I've yet to drive a car were the steering lock engages before you take the key out however.
[Edited on 18/12/08 by MikeRJ]
r1_pete - 18/12/08 at 03:32 PM
Hugh
My wife's old SL500 did just that after being serviced and valeted, the moron who valeted it steam cleaned the engine bay and washed all the lube out of the throttle linkages.... Thats a pretty powerful 5.0L V8 and auto going mad, luckily she got it into neutral rather than park!!
YQUSTA - 18/12/08 at 03:36 PM
on my mk if the ignition is fully off it locks the steering but you could allways turn it back on without starting the engine that would work.
omega0684 - 18/12/08 at 03:38 PM
if he tried all of the ways to stop the car, brakes, neutral and the key etc and NONE of that worked, then i have only one comment,
WHAT A SHODDY BUILD!
Mr Whippy - 18/12/08 at 03:39 PM
Yeah seems simple enough yet there's been plenty who have crashed from this. The guy in the Arial got this legs pulverised and his passenger broke one. He seems to have had time to build up speed and then decide to hit the wall rather than take a T-junction. Not sure why he could not have just disengaged the clutch
All quite strange
mistergrumpy - 18/12/08 at 04:10 PM
Ah that BMW driver you're talking about Whippy must've been the one on the news. He tried to blame a manufacturing fault. In the end it was proven to be lying not sure what his punishment was though.
There is a tale behind that Atom I think. The fella who did it was on the Atom owners club, the one where they don't like Nitram and gave the tale. Of course all the others agreed with him that it most certainly wasn't anything to do with the build quality and that the chassis was therefore and forever proven effective
iank - 18/12/08 at 04:16 PM
Same conclusions last time it was discussed
http://www.locostbuilders.co.uk/viewthread.php?tid=91229
nitram38 - 18/12/08 at 04:48 PM
That is why I don't build cars with combined steering lock/ignition.
On the MotaLeira, I have used an FIA switch which will cut the battery, but instead of a resistor for the alternator on the other terminals, I will connect them to the Bike loom engine cut.
That way, turning it off will kill the engine too and no steering lock dramas.
zilspeed - 18/12/08 at 05:02 PM
I don't ever remember encountering any car where turning the ignition off but leaving the key in will lock the steering.
In addition, if a modern car is put in neutral with the throttle stuck wide open, the engine will not rev its brains out either.
On full throttle, they stutter off a false rev limiter at around 5,500 rpm. You actually get more revs in netutral using part throttle.
I think our man made a James Hunt of it, to use Glaswegian rhyming slang.
BenB - 18/12/08 at 05:16 PM
All quite strange
I saw the discussion last time. Sounds like a load of BS to me.... Even if a throttle jams you're still in control. I reckon he just spanked it into a wall....
It isn't a throttle jamming that gives me the nightmares at night it's the steering failing......
BenB - 18/12/08 at 05:23 PM
Here's a thought- what engine has the Arial atom got in it? Does it's ECU not have a rev-limiter?
Even if it hadn't the blown-engine vs no-legs debate wouldn't be a long one for me. With a rev-limiter what's the worry? My 1/4 mile start technique is heavy right foot, let it bounce around on the limiter then dump the clutch. Savage but effective....
And if my weeny puny BEC for girls engine can take bouncing around on the limiter without going pop a manly boat anchor should be fine!!!!
Still reckon he just spanked it and was worried the insurance wouldn't pay up if he admitted that he was driving like a gimp!!
50M to go and he decides how he's going to crash into a brick wall? I'd decide to dump the clutch and say adios Mr Engine....
Dick Axtell - 18/12/08 at 05:39 PM
Originally posted by MikeRJYou don't immediately lose servo assistance for the brakes, it takes several presses of the pedal to lose all the stored vacuum in the servo.
IIRC Euro braking regs stipulate that servo has to retain sufficient vacuum for min of 3 pedal applications.
AndyW - 18/12/08 at 09:02 PM
he got it wrong and then thought of the excuse, most peoples reaction specially if you drive a fast car is to hit the clutch....then the middle pedal. Sad fact is he got it wrong and spanked his car
McLannahan - 18/12/08 at 09:09 PM
Exactly what I did when the throttle jammed open on the motorway in my MK Indy GSXR. Pooped myself first and then within a second had done just what Ben described.
My fault turned out to be stupidly simple and was the gas pedal jamming against its bump stop. Cut stop down and added a zip tie to prevent the pedal ever being pushed beyond it's stay again.
In all honesty I was exceeding the speed limit and did panic but after that second and giving me that time to think made me think what logically to do.
matt_claydon - 18/12/08 at 09:15 PM
Steering lock is NOT ALLOWED to come on using the same motion as switching of the engine, it must be a separate action. This is part of both SVA and EU type approval.
Engines will happily bounce off the limiter for ages, it sounds painful but manufacturers will test their engines on the limit for anywhere between 15 minutes and several hours without breaking a sweat. Never understand why people are so touchy about hitting the limiter.
