the mini!!!
rayward - 20/12/08 at 03:40 PM
finally in the garage, a new project
Ray
Mark G - 20/12/08 at 03:46 PM
looks ideal.
good luck
Humbug - 20/12/08 at 03:47 PM
hmmmm! lovely seats! Can I have them for my Locost?
mr henderson - 20/12/08 at 03:49 PM
Which bits will you be keeping?
jacko - 20/12/08 at 03:50 PM
Rust bucket
I will get rid of it for you if you like Ray
That looks like a very good project keep us all up to date with this one
Graham
speedyxjs - 20/12/08 at 03:53 PM
How much did you get that for?
Omni - 20/12/08 at 04:06 PM
Looks like you and me might be up to the same plan ;-) What you gonna do with yours????
O
Stuart_B - 20/12/08 at 04:09 PM
nice mini. looks like everyone wants a mini at the moment, as that is what i am looking for as well as i have finshed my indy. good luck what ever you are doing.
stuart
Danozeman - 20/12/08 at 04:10 PM
I hope your gonna leave them seats in!!!
rayward - 20/12/08 at 05:17 PM
cheers fellas,
got a poll going on what to do engine/
drive wise but to be honest i reckon its gonna be rear (bike)engined rear wheel drive a la Z cars ( or maybe home done and cheaper)
as for the price errrr £0. was it worth it???
been stood 10 years or so since the engine siezed is pretty solid , ( for a mini anyway)
just gotta love the 70's brown interior
Ray
Stuart_B - 20/12/08 at 05:33 PM
Originally posted by rayward
cheers fellas,
Ray
that is a great price to pay, i would like one at that price.
about the z car conversion but homemade, have you got any infomation about doing yourself(homemade) project. as i want to do one for a project but z cars ar expensive.
thanks
stuart
rayward - 20/12/08 at 05:56 PM
cheers fellas,
Ray
thanks
stuart
plan is to cut out the backend to the z cars dimensions, buy a 6 point cage and add/remove bits as nescessary to let me mount the engine + rear running gear
not sure what to do regards rear suspension yet, could go with sierra diff, uprights etc but not to keen on having different pcd wheels front and rear, i have seen a part built one that uses mini front uprights mounted in the back using one off wishbones which i quite liked the look of,
Ray
quinnj3 - 20/12/08 at 05:56 PM
If you are unsure about how to go about converting the mini take a look at the book 'How to build a motorcycle-engined racing car'. Very good info on suspension design and setup which can be applied to any car.
froggy - 20/12/08 at 06:08 PM
ive gone for de dion and five link in mine and it works fine, ive still got the jig to build a de dion its adjustable for track and you can set it up for camber and toe too if you need a lend
[Edited on 20/12/08 by froggy]
minitici - 20/12/08 at 07:49 PM
Just as well that mini was Ziebarted from new!
(Sticker on rear window)
Used to have a clubby estate that colour (and same seats )
Litemoth - 20/12/08 at 08:18 PM
Christ Froggy, I'm not sure that's strong enough is it?
Is that layshaft about 30mm? and the flange bearings mounted to 12mm plate?
Cracking piece of engineering and fabrication.
Have you got drawings for it all?
Omni - 20/12/08 at 08:20 PM
I am ditching the locost build and now doing a Mini Build too. Except I am going to make it front engine rear wheel drive Mac1 Stylee I will put a 6pt cage in it and then cut a tunnel down the middle for a prop and put a Sierra diff in it running on Indispension
Well that is the plan anyway
BTW join www.theminiforum.co.uk I am also on there. They are a very good bunch, like on here. Further more PM me and I will let you know who I am getting a full braced 6 point bolt in harness from for £280 painted
O
[Edited on 20/12/08 by Omni]
AndyW - 20/12/08 at 08:30 PM
http://www.pro-motive.co.uk/
TGR-ECOSSE - 20/12/08 at 09:11 PM
What a waste of a classic car Only kidding if you send me all bits you don't need for my collection of late 70s early 80s Minis
froggy - 20/12/08 at 09:49 PM
the de dion is mine as i built it with a single engine but all the fab work is martin keenans at mk engineering who did the twin engine conversion for me
Antnicuk - 20/12/08 at 10:24 PM
very nice bit of work, just out of interest, when running chain drive on a car, how do you lubricate the chains? I run bikes and the oiling makes lots of mess.....
andkilde - 21/12/08 at 05:29 AM
MK did a Mini a few years back that looked great and looked simpler to home fabricate than the Z-cars driven trailing arm setup, there was a good set of pictures online, they made replacement "sills" in a fairly beefy sheet-stock, sheeted the bottom in aluminum and welded the cage to the top of the beefy sheet sills, added a bit of tube structure at the back to hang double a-arms and a chain diff off -- trimmed away the floor from the firewall back to the bootlid along with most of the sills and the shell dropped onto the tube structure and affixed the new sills to the vestigial bits of original sill left behind.
Found one pic:
Cheers, Ted
ludsonline - 25/1/09 at 11:58 AM
Here's another
ludsonline - 11/5/09 at 04:18 PM
Does anybody have anymore info on the MK Mini?
iank - 11/5/09 at 05:25 PM
I'm sure if you phone Martin he'll give you all the information on cost (afaik he makes them on a one off basis).
Contact details here http://www.mkengineering.co.uk/
to be clear this is MK Engineering not MK Sportscars.
[Edited on 11/5/09 by iank]
iank - 11/5/09 at 06:45 PM
More pictures of a MK mini
http://www.freewebs.com/mega-r1/mini_index.html
