The window units on my antique TVR are held on using what look like Rawl plugs...
However...
The little plastic inserts (Rawl type plugs) have a countersunk top and the shaft splits in two when you insert a screw...
Are there specific screws and inserts that are designed for holding things into thin fibreglass/ali?
I have never seen anything quite like this before....anyone know what I am going on about? And more importantly..where to find any?
[Edited on 21/12/08 by tegwin]
I've seen quite a few cars with trim pins like that. They can be a bugger to get out in one piece. No idea where to get replacements from though.
Have a look
Here they do
all sorts of stuff like that.
Steve.
Like these, this company will usually give a few free samples
http://catalogue.jetpress.com/Industrial.aspx?intGroupID=12917
most production cars inner plastic wings are held on by such clips
If the clip has a coutersunk head it sounds more like a generic Japanese type clip. Have a look at the Jet-Press site linked earlier for Toyota
clips.
Also Wurth have a good selection of clips.
Is it anything like any of these?
http://www.wurth.co.uk/catalogue/pdfs/UK-CD_03_6055.pdf
http://www.wurth.co.uk/catalogue/pdfs/UK-CD_03_6035.pdf
Another sourc might be Woolies the trim people. If they haven't got the exact thing they can often recomend an alternative.
http://www.woolies-trim.co.uk/c-4-fasteners.aspx
