Over the years ive heard several times people saying that if you use easy start regularly on a car that the car gets addicted to it. How can this be
so?
Sounds like an old wives tale to me. Anyone got a technical reason to back up the statement?
i think its more of the engine needs it to start so there is a problem with the engine so rather than fixing it they keep using the easy start and the
problem gets worse so then the only way to start it is on easy start and therefore gets addicted to it
I may be wrong but thats how i see it
I thought easy start was used simply to get reluctant engines to start. It does nothing to whatsoever to cure the actual cause. So how can you say
needs it anymore after prolonged used than when you first used it…
Btw spray it behind an airgun pellet and it doubles the fire power
I think it comes back to what you are trying to do.
If a vehicle won't start easily, one reverts to using easy start. The vehicle starts, all hunky dory! Next time you try to start the engine,
you haven't solved the problem why it wasn't starting you try to start it, still no joy, out comes the easy start. Pretty soon, if you
don't track down why it aint firing up easily, you drop a stage out two out of this process and hence you say, 'the only way I can start
this is with easy start'! Bingo - that's why!
^^^ exactly what carpmart says.
I have this old wives tale filed next to 'engines need backpressure'.
Probably started by the manufacturers
I am not so sure. I have an old tractor that is addicted to easy start - without it it just wont go. I know what you are saying though but I just
can't see how the poor compression and broken glow plug switch could be affecting it.
Yeah know what you mean - I'm addicted to easy Start just love the smell of the Suff. Sod spraying it in the engine just sniff the can..
PS sniffing Chemical can and is dangerous to your health
My lawnmower is addicted to hairspray and deodorant. Easy start is much to good for it.
Still like the look of suprise on my daughters face when I borrowed her stinky stuff in a pink can to get the bugger started..so she could mow the
lawn
Cant think why it works first time when you use some down the carb. Do spark plugs go off or does the petrol left in the can from 3 seasons ago
change its self back to the nasty chemicals it was made with.......
My lawnmower is addicted to hairspray and deodorant. Easy start is much to good for it.![]()
Still like the look of suprise on my daughters face when I borrowed her stinky stuff in a pink can to get the bugger started..so she could mow the lawn![]()
I believe Easy Start is a rip off of this
START YA BASTARD
Though you cant have as much fun with the name...
Brake cleaner is just as good and doesn't cause the knocking that Easistart does
