Tomtom USA maps
macca1 - 24/1/09 at 08:42 PM
I've just recieived a genuine Tomtom SD card with USA&Canada maps on but when I unstall it in my Tomtom 530 it just stalls after the first screen loads.
Is there a problem with the card or is it just down to the fact I aint in the good old US of A yet?
I don't want to get on my hols, turn it on and go "Oh poo!" that doesn't work.
Col
nitram38 - 24/1/09 at 08:51 PM
Don't you have to select the map from your menu's?
I have a 910 and a 930 and you have to switch maps.
I have just bought a 940 so the other two might be up for sale. ( hint hint ! )
My 930 was used in Florida with no problems. Both have the tmc aerial.
macca1 - 24/1/09 at 09:08 PM
The 910 has the maps preinstalled doesn't it, I only know this as thats what I used last year but I have now given that to a work mate.
I was sold the card as being compatable with all Tomtom's that use an SD card, but after looking on their website I'm beginning to think that not true
I may be wrong but it looks like its bound for Fleabay and I'll get the correct version direct from Tom.
Col
nitram38 - 24/1/09 at 09:11 PM
You may have to point to it or transfer it to your main memory.
If I plug either unit into my PC, both Europe and usa maps are in the same folder.
Might be worth a try before you get rid of it. You can always delete the file if it does not work.
matt_gsxr - 24/1/09 at 10:23 PM
If it doesn't work here it won't work there.
You can normally see the map even if you aren't there.
If you bought it from a shop then get them so install and sort it.
Matt
