Twin pluse jet car and they only generate about 1200lb of thrust each , it
would keep people off your tail
Like that, but as usual got distracted by following other links and came across a loony on a bicycle
jumping a moving van with ramps.
Which was funny, and probably quite painful!
Simon
This one got my attention
LINKY
I like the bit when the fireman said that the people were complaining from a block and a half away!
Originally posted by Simon
Like that, but as usual got distracted by following other links and came across a loony on a bicycle jumping a moving van with ramps.
Simon
Pulsejets are amazing,
wish i had some big sheet rollers , i'd build a "lockwood" straight away
Problem with pulse-jets is they require airflow to make good power. At slow speeds you're better off with I/C.... When you get some air flow going pulsejets sure give some welly....
Nice engine.
That bloke on the bike must have broke something!!
Originally posted by Danozeman
Nice engine.
