Tin top exhaust problem
eznfrank - 4/3/09 at 01:13 PM
I've got an Alfa 147 which I plan to get rid of in the next few months, however, it has recenlt developed an exhaust "rasp", which I initially thought was the cat going however I am told it is actually the flexible piece of woven exhaust where it connects between the manifold and cat.
The problem is that these are £700+vat and the car isn't worth so much nowadays.
Do we reckon I'd be ok trying to wrap it in exhaust wrap insetad?
adithorp - 4/3/09 at 01:18 PM
Yep, if its just vibration causing the noise and not a blow. Or just sticking a couple of Jubilee clips around it should do.
adrian
trogdor - 4/3/09 at 01:20 PM
you could do what my dad did with his nissan largo, when the exhaust flexable thingy went.
Found a universal flexable thingy and found a flange from a exhaust specialist that would fit into the flexible bit and bolt to the largos exhaust. then welded it together. I think he managed to reuse the other end.
That bit cost about £20 and the universal thing i think was something like £50. I think www.nfauto.co.uk do one
would be the cheapest way to fix it properly. Not sure how well the exhaust wrap stuff would work.
[Edited on 4/3/09 by trogdor]
Mr Whippy - 4/3/09 at 01:35 PM
£700 dude these cost £18 from CBS
CBS linky
Paul TigerB6 - 4/3/09 at 01:36 PM
Can you not pick up a clamp on (or weld on) exhaust flexi pipe to replace the offending item??
Ebay have various sizes available so should find what you need
this sort of thing
dinosaurjuice - 4/3/09 at 01:50 PM
this sort of thing
ive used one of those, and despite being stainless steel it welded fine with my MIG to the mild steel tube.
Danozeman - 4/3/09 at 07:36 PM
Id do this. or a clamp on if you havent got a welder. Muchos cheapness.
