brake m/c sizes
theconrodkid - 17/3/09 at 03:33 PM
i have a mundingo master cyl on my chariot,i believe its 0.75 bore? and the brakes are pretty crap.i am led to believe that a 0.7 bore would be better.
sooooooo instead of looking for a smaller cylinder and having all the agg of moving pipes and mountings around would it be possible to sleeve the existing cylinder and piston down to 0.7?
your thoughts please
daviep - 17/3/09 at 03:44 PM
No
Your sleeve would only have a wall thickness of 25 thou or just over half a millimetre.
Even if you managed to make a sleeve you wouldn't be able to seal it in to the m/c reliabley. It would be too thin to be a press fit and you don't have enough wall thickness to fit an o ring or similar seal.
Just my opinion
Davie
britishtrident - 17/3/09 at 03:55 PM
Mondeo master cylinder wil be 0.83" (21mm) bore or more -- but it isn't worth the effort of doing it.
britishtrident - 17/3/09 at 03:57 PM
Originally posted by daviep
No
Just my opinion
Davie
It is a fairly standard method of repairing classic car master cylinder where the supply of new ones as dried up but not worth the effort in this case.
theconrodkid - 17/3/09 at 05:08 PM
not the answer i wanted but hey ho....cheers chaps
