hi all,
im having to replace the front springs of my corsa because one of the springs sheared in two and started rattling all over the place! now i have
removed the suspension strut from the car without any problems and i have put my spring compressors on so i dont get a face full when i remove the top
nut, but thats my problem i cant get the top spring undone!
its am 18mm nut and im using a breaker bar on it and an extension on that but when i turn it the entire damper turns with it, i have tried using mole
grips on the damper tube but still no look, have any of you got any wise words or tricks of the trade you would like to share to help a por guy out
Alex
[Edited on 1/4/09 by omega0684]
We had this problem at college. We ended up having to use an impact gun and even then it took ages.
on all cars i have done springs on there is an allen key hole in the top of the damper that you hold while undoing the nut with a cranked ring spanner
windy gun. (air powered impact wrench)
Angry grinder to kill the nut, with spring clamps in place. Then refit with new nut.
This man has the answer - no need to got attacking it with a grinder or mole grips![]()
Look on the top of the damper rod and you'll see a hex/allen socket - usually around 8mm. Use a cranked ring spanner rather than a socket and then use the allen key to lever against the spanner. Often best to hold the damper unit in a vice agled slightly away from your face in case the spring gets a mind of it's own too.
i crackek it off while it was still on the car though before i removed the top bit
thanks for all your advice there guys in the end i went with an air impact wrench that i remembered i bought ages ago but forgot i had it until today,
got the nut off in seconds! fantastic bit of kit, ive given each strut a good going over with the wire brush on the drill and then put them all back
together and they are now back on the car, here is a picture of the bit that sheared off
