After the supplier I ordered a shed load of bits went bust today...I'm after somewhere else for my bits!
I'm needing...
Nylocs, nuts, set bolts, normal bolts, rivnuts, washers, allen headed bolts....
I had about 100 of each ordered but I don't need that many, just following Steve's advice to stock up while I could!
Any recommendations please? I'm in a bit of a hurry for it all now and even tempted to use Screwfix....
I used screwfix for all the metric stuff I needed
i get all my stuff from here,
Wrights Auto Supplies
the guy is awesome, never let me down, i just turn up at his door and say 'i want this' and he dives into the racking and pops up with
everything you ever wanted
as said, for the metric stuff you won't get cheaper than screwfix but the range is fairly limited.
Thanks for replies guys.
Screwfix, Namricks and Wrights don't appear to do rivnuts though?
Is there a one-stop shop for all?
Thanks again
Rivnuts, ebay is cheapest iv found.
They have several names aswell. Threaded inserts, nutserts, rivnuts etc.
Thanks Pants and Dan, I've bought some rivnuts from Fleabay.
Will try and source everything else elsewhere.
do screwfix obtain their cheese bolts from same manufacturer as B&Q, if so, I';d be wary of using them for anything other than ornamental
purposes.
there is a fastener place that would ahve all the stuff you want and more but it is local to me so no use for you. I daresay they will post but....
I've always bought my rivnuts from RS but they call them something else....
They also do bolts etc....
[Edited on 2/4/09 by stevebubs]
I've always used orbital in Watford.
Link
Originally posted by 02GF74
do screwfix obtain their cheese bolts from same manufacturer as B&Q, if so, I';d be wary of using them for anything other than ornamental purposes.
