Hi guys,
Just wondering if there is any freely or cheaply available software which allows you to put in the dimensions of your suspension/steering system and
then perform what-if analysis? You know, something where I can put in the various arm lengths and angles and then calculate camber, caster, toe etc
and then make some changes and see the effect.
I don't mind if this is a spreadsheet or an actual program as long as it's not expensive.
Craig.
I use susprog - but its not cheap!
Are there any demo versions of susprog available? Perhaps with limited functionality?
Craig.
The best has got to be the Lotus Suspension software, but finding it will be very hard. And it may be a bit complex to use. Not sure on price or anything like that, no doubt it's not cheap.
