Yesterday I stuck my foot all the way through my trailer's old wooden floor (and nearly broke my ankle).
I felt this was a sufficient enough message from the old girl to warrant an upgrade.
I've ripped all the wooden centre floor area out and am now on the look-out for a metal equivalent.
I was slightly shocked by the price of aluminium chequer plate.
Can anyone please recommend:
(i) What type of metal (I presumed aluminium would really be the only option for an exposed floor kept outisde?)
(ii) What type of sheet? Thickness? plain or chequer plate? (it's for the centre area of the trailer and will not be taking the car's
weight)
(iii) Best place to buy the stuff from (cut to order).
She's in a sorry old state and keeping my fingers crossed that I'll be able to finish this project before my next track day.
Any help greatly appreciated as always.
Kyle
[Edited on 26/4/09 by The Great Fandango]
When you say centre area do you mean the strip down the middle that'd be inbetween the wheels, or would it have to take the car's weight as you're rolling it on?
~If its for the centre area where the only weight will be ramps, tools, or tow equipment to get the car onto the trailer, then id go and byu some
1/2" marine ply or similar. I would also look at replacing the tracks where the car wheels go, for Steel expanded mesh.
Just a thought, but its difficult to say without a photo.
Hi Kyle,
not sure if this is any use to you but as my donor was stripped yesterday i have the metal boot cover from a sierra estate ( i kept it as its more or
less flat & thought it might turn into a shelf somewhere ), my thoughts are if it was cut into two pieces then subject to the length of the gap
you need to replace it could be welded into place, be strong enough etc, happy to cut to your dimension & come down & weld into place, in
return for a passenger ride at a track day ??
cheers
andy
marine plywood, preferably birch, with a descent sealer will last for years. ~17mm
easy to screw stuff down to if transporting other things too
Old central heating radiator. I used one to make the footwells on my car due to the pressed shape they are very strong. Best of all I got mine for
free.
[Edited on 26/4/09 by Bigheppy]
Thanks for all the replies guys... looks like marine ply it is then.
As for a photo... I'm simply ashamed of the trailers present condition so I won't be posting a photo! lol
Andy, I'm not sure the boot cover will be long enough. The total area needing covering is approximately 3" by 10". In any case,
you've already secured your passenger experience!
Some peeps did ask... the strips each side of the old wooden area are metal and in good condition - it's literaly just the non-load bearing
centre area I'm replacing.
