Help! (Maybe should be in the wanted section)
PAULD - 8/5/09 at 07:10 PM
My daughters just drove over a sleeping policeman in a '98 fiesta and the engine died. There's pressure at the fuel rail but no spark and the plugs are clean and dry.Any suggestions gratefully received.
balidey - 8/5/09 at 07:14 PM
if the 'crash cut off sensor' took a knock then that could do it, not sure where its located in that car.
Gary 7 - 8/5/09 at 07:15 PM
Could be the fuel pump inertia switch needs resetting, i think its down in the drivers footwell behind a trim panel near the floor.
MikeR - 8/5/09 at 07:20 PM
if she's triggered that - how fast was she going???
I'd also have a quick check of the suspension etc once its running!
PAULD - 8/5/09 at 07:22 PM
Tried the inertia switch seems ok (would I be getting fuel pressure if it wasn't?)Had a plug out to test for a spark -None.
t16turbotone - 8/5/09 at 07:38 PM
this happened to my sisters fiesta when she bumped up a kerb, cause was found to be with a broken earthing ring crimp terminal in engine bay.
PAULD - 8/5/09 at 07:52 PM
Just checked, the engines earthed and there's 12 volts on the centre pin of the coil pack. Has anyone another suggestion please?
