I want to upgrade the brake pipe on the tintop next weekend, partly so i can use the existing ones on the locost and also because i am going on a tour
in august which is going to involve a lot of mountain roads.
Where si the best place to get stainless braided brake hoses from for a 97 jag xj6?
If you can tell me what end fittings you have & give me lengths I can make them for you no problem, unfortunately i don't have a listing for
spec of them.
Regards Russ
Cheers russ. Is there any way of finding out without taking them off though?
The standard OEM rubber covered hoses are much more suitable for a normal road car ---- really zero benefits from braided hoses and a number of disadvantages -- for example you can't clamp the brakes hose and they aren't fit and forget.
If you take a careful look at the unions on the end of the existing hoses & the copper/steel pipes going into them, also at the caliper ends you can usually see if they are the standard M10 size, in which case tey will be M10 x 1.0 or if they are something larger (unusual except on Yanks), you should also be able to see what is female/male or a banjo fitting, I would be able to work out what will be convex/concave etc.
