Collected my new audi tonight... 2 hours later it's broken (rant and questions)
paul the 6th - 3/7/09 at 10:39 PM
well I'm absolutely F***ING livid.
Just splashed out £15 grand on a 2007 s-line a3 (2.0 tdi) which I collected from Volkswagen York (jct600) at 6:30pm. Stopped at wrigglypigs house, showed him the car for 15 minutes, went home, waited for the missus who was messing around so said I'd go fill it up with diesel and then come back in 15 mins.
Filled up with excellium diesel and went for a razz to some local twisty roads towards rufforth from York. At about 60mph in 5th gear, I pressed for a tiny bit of acceleration but the engine just bogged down and the rev's started to drop very slowly... Very Odd I thought... carried on till the next available side road and pulled in to do a u-turn and head home. Engine had stalled and dash lights were all on.
Tried to start the engine twice - it turned over but wouldn't catch. Pushed it out of the road and tried once more but gave up, called volkswagen assistance and wandered down the road to the local yokel pub where all the local yokels took the p!ss out of me for the better part of 2 hours. On the bright side it was £1.70 a pint, on the bad side I only had £3 on me
Recovery guy seems to think it could be the injector pump which has gone as turning the ignition on and off was priming the system i.e. diesel spraying out of the return pipe but not enough to get the engine to fire. Recovered the car back to my house and I'm gonna ring volkswagen tomorrow.
This is the first reasonably expensive/luxury car I've ever had, all the others have been bangers and sub-£7k cars which have all been flawless. This one was great to drive for the first 2 hours and now it's just an expensive ornament sat on my driveway...
Can anyone offer any advice on this at all please? What it could be, what could have caused it? (yes, I've already checked 5 times I definitely filled with diesel and not petrol, checked the receipt three times and even went back to the petrol station just to have a quick look at the pump, definitely excellium diesel)...
NOT a pretty sight... his arse is awful as well
[Edited on 3/7/09 by paul the 6th]
blakep82 - 3/7/09 at 10:44 PM
Thinking about it - 3/7/09 at 10:46 PM
All under warranty I guess / hope.
eccsmk - 3/7/09 at 10:52 PM
gutted for you
i really hope you manage to get it sorted out!
[Edited on 3/7/09 by eccsmk]
paul the 6th - 3/7/09 at 10:53 PM
One years manufacturers warranty left and a JCT600 give a 30 day guarantee against this kind of thing happening so technically they should sort it.
Managed to laugh the yokels off for 2 hours but as soon as I've got in and had a bit of quiet time to think about it, I'm absolutely gutted. I can just about afford it and I've been looking forward to a new car for bloody ages (mondeo was starting to go mega wrong = £1000 to keep it or part ex while it's still worth something)... then this has happened.
Just hoping I won't have to push to hard to get a courtesy car/get VW:York to collect it from my house, as I'm meant to be in reading on monday...
omega0684 - 3/7/09 at 10:54 PM
step 1: take it back, get your 15k back
step 2: buy a banger, it'll be flawless, cost you a grand,
step 3: build your own sports car for £250
step 4: pocket £13,750!
EASY MONEY!
P.S, sorry to hear about your mis-fortune mate!
[Edited on 3/7/09 by omega0684]
Thinking about it - 3/7/09 at 10:56 PM
Alex. That Dax looks quite good for £250
paul the 6th - 3/7/09 at 10:57 PM
EASY MONEY!
good idea
dave1888 - 3/7/09 at 11:01 PM
Jesus that's unreal £1.70 a pint.
Ninehigh - 3/7/09 at 11:24 PM
It goes back and they fix it for free, they can't possibly blame you for breaking it after a few hours. Throw the "Sale of goods fit for the purpose" act at them if need be. I'd have got the tow truck guy to take it right back to them.
Definately refuse to hand over a penny until it's fixed, properly. Cancel the direct debit if need be and demand your old car back if they won't give you and kind of courtesy car.
Do not take no for an answer!
paul the 6th - 4/7/09 at 12:21 AM
cheers for the tips ninehigh
was considering getting the car recovered to VW York but he'd have to have left me there (no lift back home again) and no one would have been there to 'accept' the car as the dealer was shut.
Sales opens at 8:30 so I'm gonna call first thing and explain to the GSM they need to have the car picked up & a courtesy car arranged, an then see what the intial response is before pulling any "Sales of Goods Act" or "the DD is cancelled til you sort this" type stuff on them.
blakep82 - 4/7/09 at 12:31 AM
EASY MONEY!
wow, do that once a month, you'd be loaded!
RK - 4/7/09 at 03:28 AM
Don't know about there, but Audi's are one of the most expensive car around to get repaired once your warranty expires. Porsche are slightly more, I hear, but in my city, they are done at the same place.
bimbleuk - 4/7/09 at 03:38 AM
I'll certainly agree they are expensive if you use the dealers but actually quite reasonable if you source the parts yourself. Most modern diesels have very high precision pump/injector parts etc which do cost 100s if not 1000s to replace.
[Edited on 4-7-09 by bimbleuk]
Staple balls - 4/7/09 at 03:55 AM
I've heard similar from a mate who owned audis and porsches.
When he wrecked his porsche, he saved a fair bit of money upgrading to better, non OEM parts, as with all things it's worth shopping around.
Shandylegs - 4/7/09 at 05:59 AM
really does seem luck of the draw.
Good friend has run an A3 2.0tdi as a company car for the past couple of years covering over 90k without one single problem.
I buy a low milage 55 plate A4 1.8T estate privately expecting trouble free motoring and have had to spend approaching £500 in less than 2 months sorting out faults (Airbag sensor, ABS sensor and 2 x coil packs at different times) - so much for bullet proof engineering!
ozzieboy - 4/7/09 at 07:33 AM
I Think they call it .....
"Vorsprung durk technic "
or is it crapnic!! sorry to here im sure they will sort you a loan s3 to make up for it while it has the work done!!
myke pocock - 4/7/09 at 07:36 AM
Whilst you are undoubtedly gutted, give them a chance! You havnt even contacted them yet. Any garage worth its salt will help you out as much as they can in this circumstance. As someone else commented, luck of the draw same as "Why does a bulb go at MOT time when you checked it the night before"?
SeaBass - 4/7/09 at 07:50 AM
Sorry to hear about your problems - I'm sure the dealer will sort it for you without issue...
I've run Audis for years. I only use OEM parts purchased through either VAG parts or my local VW dealer who are much cheaper than the Audi dealer for the same parts.
I've done all the work and servicing myself and they've cost very little to run. To be honest my Audis have been exceptionally reliable compared to work colleagues Vauxhalls, Fords, Renaults etc which were constantly in the main dealers at dealer rates. Having said that I wouldn't touch any diesel even if the car was free!!
James
[Edited on 4/7/09 by SeaBass]
pgtips - 4/7/09 at 07:59 AM
Audis/vw's are great cars till they go wrong...... out of warranty usually.
They do suffer with fuel pumps and fuel injectors big time. You are very lucky the car is still under warranty as the injectors are stupid money. Had one the other day car still in the three years but was high millage one so VW said no to the warranty. The first problem he had was with the fuel pump gone down.Pump was on back order for 8 months. Had it down my yard for all the time. Fixed and three months later two of the injectors went down. Customer asked to renew all 4. £1500.00 just for parts.
Saying that.....they are fantastic cars otherwise.
pgtips - 4/7/09 at 08:00 AM
James
Have you tried to change the rear brake pads on the newer Audi's/Vw's yet?
Peteff - 4/7/09 at 08:02 AM
Gutted for you mate, get back to bangers. We bought a Kia Sportage last year as a stop gap motor for £1700 and it just gone through it's second MOT with nothing wrong.
martyn_16v - 4/7/09 at 08:17 AM
Originally posted by Peteff
bangers ....... £1700
That's not a banger, that would be the second most expensive car i've ever owned!
matt_gsxr - 4/7/09 at 10:05 AM
Sounds like good old fashioned bad luck to me.
I have had an Audi A4 1.9Tdi for the last 7 years. Now it has done 219k miles.
Main dealers are not worth bothering with as their prices are silly. They even quoted me £120/hour for diagnosing a fault (no thank-you)! Local small guys can do all the stuff as the engineering is common across loads of different cars.
A few design faults on the A4 (1998 model in my case); ignition switches fail that can burn-out the starter unless you realise something is wrong, suspension parts at the front have limited lifespans (maybe 70k) and there are lots of them, lower door trims suffer from electrolytic corrosion and fall off (at 100k), immobiliser can be a bit over-enthusiastic (but responds to wiggling).
But to be honest the car is excellent. I will definitely buy another Audi.
A good site for information is vwaudiforum
Matt
zilspeed - 4/7/09 at 11:52 AM
I'm a VAG convert these days I have to say.
the Audi A4 which I have been running for some months now and has cost very little to run in terms of parts and repairs. There is a solitary clonk from the front end, but that's an easy fix.
Just bought the Golf GTI that everyone said I shouldn't and I find that equally impressive.
Both have been banger money purchases and feel all the better for it.
Benzine - 4/7/09 at 11:56 AM
1. Return car for full refund
2. Use money for cheap car and have loads of cash for fun things
3. ????
4. PROFIT
RK - 4/7/09 at 01:04 PM
I have a work neighbour who has an S4 that he gets serviced at a small garage, which he highly recommends over the Audi/Porsche dealer. So maybe they don't have to cost the earth after all. My A4 Avant just ran out of warranty, so I can't lose sight of this guy!
paul the 6th - 4/7/09 at 02:21 PM
Called dealer, they appologised and told me to ring VW assistance who would come and recover it to the dealership. They've also arranged a courtesy car which arrived before the audi was recovered (vauxhall astra). Service has been good but still pished off with the car going wrong so soon..
miikae - 4/7/09 at 02:29 PM
Sounds like JCT600 are trying to save money as when my old Porche was in for a service they gave me a brand new one to run around in for a couple of days .
Mike
paul the 6th - 4/7/09 at 02:59 PM
never been a big fan of vauxhall to be honest but the 1.8 astra seems quite spritely (not driven a petrol car properly for a good few years now.. Nice to have some rev's back and the brakes are keener than my mondeo's ever were....
but it's still not my audi lol..
Anywho, just glad to have transport and that it's back at the dealers getting fixed, on monday, so all should be well. Only problem is I'm working away monday to thursday next week so if it's ready for collection in the meantime they'll have to hang onto it for me
norm007 - 4/7/09 at 06:10 PM
Never mind.
At least you gave me a giggle with the recovery mans "builders arse" photo. LOL
By the way, which pub were you in?
Ninehigh - 4/7/09 at 06:21 PM
Yeah to be fair you'll always get one that goes wrong, and I've recently come to the conclusion that the company being nice about it is really important. O2 have had awful internet service but at least when you phone up they're giving a cr@p
paul the 6th - 4/7/09 at 06:22 PM
Tankard inn at rufforth
Originally posted by norm007
Never mind.
norm007 - 4/7/09 at 06:26 PM
Might have to have a look in there sometime.
Bet recovery man would be "red cheeked" if he saw your photo???
the_fbi - 5/7/09 at 09:25 AM
Maybe as simple as a boost pipe coming off. I know earlier VAGs were prone to this as the clip assembly they use is steel on ally, the ally nipple gets worn away and the pipes just part company.
Generally happens if they've not been re-assembled correctly after a service.
It'll all be OK, damn nice cars
Danozeman - 5/7/09 at 04:06 PM
sorry to hear about that bud. did they tell you what was wrong??
Also they should really have given you like for like car as a courtesy... Id have been well annoyed with an arstra.
paul the 6th - 5/7/09 at 10:40 PM
aye they said "we will try and find another audi for you as we have a uk fleet which act as courtesy cars for this kind of thing".... then they rang later and said "unfortunately we didn't have any audi's spare so we're getting a car in from national car rental, it'll be a similar sized hatchback but we won't know which one until it arrives with you"....
so had a wee bit of fun playing rental car rally yesterday
unfortunately VW workshop is closed til early tomorra morning so won't know the score until they ring me (or I ring them... more likely me thinks). Will report back once I know the score, just glad I've got a courtesy car and the whole thing is covered by a 30 day guarantee from the dealership & manufacturers warranty for another year
