Anyone on here got an Ford Focus factory LPG
MK9R - 15/7/09 at 09:05 AM
I've got a 2003 factory fit LPG Ford focus, i'm just giving it a service and want to change the gas side LPG filter, but there looks like there are 2 filters, or is one of them something else?? Seems very strange to have 2 filter 300mm apart??
britishtrident - 15/7/09 at 09:34 AM
General LPG practice (not Ford specific) is to have 2 filters one is a wet gas filter which is usually built into the solenoid valve fitted in the engine compartment. just before the Reducer/Vapouriser the other is a dry gas filter between the vouriser and the injector block.
This web page might help. http://www.tinleytech.co.uk/acatalog/Filter_shut-off_valves_and_filter_elements.html
MK9R - 15/7/09 at 09:36 AM
Thanks, but i know this, the 2 filter looking things are on the dry side after the vapouriser
britishtrident - 15/7/09 at 09:51 AM
Hmm (meaning ain't got a clue) try asking here
http://www.lpgforum.co.uk/
MK9R - 15/7/09 at 10:14 AM
LOL, just posted it there!
sebastiaan - 15/7/09 at 05:13 PM
Cool, somebody's actually got one of these on here. I did part of the engineering (mainly emissions tuning and driveability calibration)
Here goes;
IIRC there is a filter in the (16mm) dry gas hose followed by a 16-8-8-8-8 splitter further downstream. I think the filter unit was fitted with a replaceable filter locked in place by a compression spring washer. That way, you can separate the filter without taking the hoses off.
You should be able to get the filter from the Ford dealer or from a gas conversion specialist. The brand of the filter is Necam / TeleflexGFI. Take care you do not slit the O-ring when you put everything back together.
There is also a filter in the "wet" gas line to the vaporizer. Change that also. It is mounted in the shut off valve (brass, the lid on the filter is around one inch in diameter with a hexagonal piece on top to unscrew it).
Good luck!
MK9R - 16/7/09 at 06:26 AM
Here goes;
Good luck!
Brilliant!!! Ford dealers are a waste of time as they know nothing about the LPG and LPG fitter don't seem to know the system, but Locostbuilders has the answer!!!
I had a another look last night and realised it was a splitter, but didn't realise the filter was a changeable one! I had already ordered a throw away filter so will probably end up fitting that this time, but keep hold of the original and replace the filter for next time. I haven't ordered the wet side filter yet as i haven't really had a good look for it yet.
I must say the conversion is very good, you can't tell what you are driving on, well not now i have just replaced plugs, leads and air filter (running a lot smoother), its amazing how the spark quality effects LPG running compared to petrol
MK9R - 19/8/09 at 07:47 AM
Here goes;
Good luck!
see here:-
http://www.locostbuilders.co.uk/viewthread.php?tid=119840
[Edited on 19/8/09 by MK9R]
MK9R - 26/8/09 at 07:55 AM
Here goes;
Good luck!
Sebastiaan you have u2u
[Edited on 26/8/09 by MK9R]
