hi peeps, got the chance to buy a vivaro van with knackered diesel engine.
Ive been running lpg vans for years now and can see absolututley no reason to go back to diesel.
Question is what petrol engine will fit into vivaro, anyone know??
thanx
Check what renault engines are available for the traffic.
I believe that they are both the same.
here comes the BEC crowd
or should that be BEV
you'll need a gearbox to go with that too though
[Edited on 20/7/09 by Mr Whippy]
Im voting a jet engine in the back!!!!! lol. gotta go for something mad!!
I believe there's several vans with the same shape... Renault, Vauxhall, and i'm sure there's a 3rd...
Check them out for the choice of engines.
Nissan movistar...
if the gearbox is ok, you want a F4R 2.0 16v engine as fitted to lagunas, scenics, clios, trafics, espaces etc etc.
Beware though IIRC the only f4r engine without vvt is the 2.0 scenic (old shape) that was built for the UK.
All the others and the cypriot import old shape scenics had the camshaft dephaser fitted.
Shaun
