hi all, i´ve got to change the front shocks on my old audi 100 (1989) & have baught new ones but have no clue how to to do that , i´ve had a look
arownd & it looks like a simple thing to do . has anyone done this or know how i should go about doing this ?
thanks for the help.
cheers
Samy
removing the shocks is pretty straight forward,2 bolts through the front hub and a nut where it goes into the engine bay,you may need a spline tool to
hold the middle of the shock while you undo nut.
to remove/replace the spring you need a compressor,dont try to bodge it,(it can take your head off if it lets go)get a proper one or take the struts
to a garage to get them done....simples really
i have a audi 100, its not quite so simple, sadly
its a one piece strut, so you need to remove the the bottom ball joint, drive shaft stub and the caliper
then to get off at the top remove the 3 10mm nut that hold the strut top to the shell, do not remove the big nut, this holds the spring seat against
the spring
now with a lot of jiggling and trying to get of the lower arm remove the strut, then disassemble the strut top assembly with the spring held by spring
compressors. there is a special vag tool needed to remove the locking nut on the strut body that holds the damper in it, however i found a stilson
works
having done this job with the aid someone the first time id call a fairly intense job, however i can now after working on 3 20 year old audis do this
fairly quickly
[Edited on 29/7/09 by goodall]
hmmm , i think i know what you guys mean but i´m not realy sure how to remove the old dampers , they dont appear to be held in place by any nutt or
bult it looks like they just slide into the upright ! i´ve taken the part in the engen bay apart & the damper was just sticking up throw that
opening , the spring is safe & sownd & it didnt look like i would need to take that apart at all , i tried to pull the damper up & out
through the top ( into the engen bay ) but it feels like its held down or in place by something!?
so i´ll have another go at it , would have been nice with an AUDI 100 manual
thanks for the replys
cheers
Samy
ill take a pic or scan of the exploded diagram for you itll be clear then
thanks so much , that´ll be great. i tried to find some drawings online but had no luck & i´m sure it would have helped alot , like the saying
goes (one picture is worth a thousend words )
thanks again
Samy
pull this pic of www.vagcat.com its very useful have a audi or vw
part 14 is the cap nut that holds the damper into the strut body
hi goodall, thaks alot for all your help that realy cleared thing up .
cheers
