I need to remove the powder coating from some steel that i have.
Some of it is flaking and will peel off but some of it seems to be stuck well, will nitromors remove it?
Or is there an easier way?
Used Nitromors when I removed the powder coating from my front wishbones , Angrygrinder with wire brush helps.
I used nitromors and wire brush when I did my rear end - ooh err.
