Elise value give me your guesses
locoboy - 18/8/09 at 04:04 PM
I have got wind of an elise that is a T reg.
Quick sale and it needs 'attention' any ideas on a ROUGH value.
I know its hard to say because if the engine is scrap or the heads ferked its going to cost some money but even to the nearest 1500 quid would be a good start.
I can see good ones on auto trader that are anywhere between 6-7K.
Any advice appreciated too just incase i go and have a look at it!
I know about the head shuffle/ gasket issues. anything else?
[Edited on 18/8/09 by locoboy]
Guinness - 18/8/09 at 04:12 PM
If an old but good 'un is worth £6k, then I'd guess a car with issues is worth £4k??
£3.5k to a desperate owner.
Head gasket isn't that expensive to do, and if it's really knackered a lot of people have done engine swaps to Audi turbo lumps, or Honda VTEC conversions.
My 2 p.
Mike
MikeRJ - 18/8/09 at 04:14 PM
It's so hard to say without more information, but even really tatty, but roadworthy ones fetch good money.
If the chassis is damaged then it will be virtually salvage value due to the difficulty and cost of repair. I wouldn't touch one with a long barge pole.
Engine problems in an otherwise tidy car is absolutely the best outcome you could wish for, much cheaper and easier to fix than bodywork, suspension or chassis issues! The cheapest Elise I've ever seen was a very rough looking one with a Cat C history, and that sold for ~£4700 IIRC.
oadamo - 18/8/09 at 04:19 PM
theres one on the scrapyard by me thats been rolled but loads of parts are still good.
(autobits) clarks lane willenhall
adam
graememk - 18/8/09 at 05:00 PM
i wouldnt give more than 5k, as your buying a unknown really.
locoboy - 18/8/09 at 05:17 PM
the only info i can get is this
" there is a sensor that knocks it down to 2 cylinders when you put your foot down - not good when your overtaking. Its something to do with the timing i think"
Clearly not all that clued up but thats all i can get from them.
scootz - 18/8/09 at 06:20 PM
I wouldn't worry about the engine too much.
Satisfy yourself that the rest of the car is OK... chassis, brakes, suspension, body, etc. HPI it!!!
Then go in with a low offer on the basis that it WILL need a new engine... I would think market value less £1000-1500.
britishtrident - 18/8/09 at 06:33 PM
Running on 2 cylinders when pushed hard sounds like it needs coil packs+plugs+leads ---- Coil pack is the same as early Freelander 1.8 they are actually seperate coils mounted on the end of the head which are shared between a pair of cylinders.
However the VVC mechanism can get broken and that is more expensive to fix.
It is likely to have been neglected so will need a cam belt change included in the budget anyway -- not as simple as the normal K to do but still DIY
If I were buying something with this type of engine fault I would want to read the fault codes first and check the VIN number against that stored in the ECU.
StevieB - 18/8/09 at 06:43 PM
Old but good ones tend to go for nearer £8k, especially the later S1 cars (there's still a lot of people out there who prefer the S1 over the S2's styling - they're all fools as the S2 is slightly lighter, slightly faster and far better built...)
If it needs attention then you might get it for 5-6k. Ultimately there are plenty of K series ngines around so a replacement is not too hard to find. In fact, if it needed replacement you could always stick a VVC in it instead, unless you fancy spending a lot more and going down the Type R route
Peteff - 18/8/09 at 06:51 PM
£1500 is my guess
