Spacer needed
philw - 21/8/09 at 07:45 AM
Can anyone make me a spacer the same as in the picture please
Jasongray5 - 21/8/09 at 07:48 AM
Flackmonky is your man i tink?
theconrodkid - 21/8/09 at 07:59 AM
i think thats the least of your problems,you appear to have a hole in your block
matt_claydon - 21/8/09 at 08:07 AM
Stack of washers is the locost solution.
nick205 - 21/8/09 at 08:13 AM
That would be right up flakmoney's street - which reminds me I need to get my engine breather off to him for some machining work
philw - 21/8/09 at 08:32 AM
I've got that already, it just looks sh**, it's one of those little things that need doing that you never seem to get around to
philw - 21/8/09 at 08:36 AM
I've just Gripfilled a clear perspex sheet over it so you can see the internals moving, it looks really cool but looses a bit of oil when warm.
flak monkey - 21/8/09 at 08:49 AM
I'll make you one if you like?
14.5mm long
10.5mm bore
20mm OD?
U2U me if interested and we can sort something out.
02GF74 - 21/8/09 at 09:15 AM
that M10 bolt is the only one that holds the alternator rigidly -the other end is the adjuser which is usually relativley flimsy slotted plate.
So make the spacer as large a diameter as poss providing it fit - the boss on the alternator is machined so measure that but 20 mm sounds about right.
internal bore 10 mm - use 10 mm drill, M10 bolt will slip through that.
flak monkey - 21/8/09 at 10:01 AM
Engineering spec for clearance hole for M10 is 10.25mm to 10.5mm
MikeRJ - 21/8/09 at 10:34 AM
Which is probably about what you get with a hand held drill and a 10mm bit
flak monkey - 21/8/09 at 10:46 AM
Lol, true, but not if the holes drilled with a decent machine
MakeEverything - 21/8/09 at 11:56 AM
Im standing on Flak Monkeys side of the fence on this one.
