daft question, but anybody know what battery I need for a mini clubman estate (1977, 1100, not that that will matter)
Nowhere round here has a decent catalogue and by the space where it goes I'm guessing its not the same as the saloon one!
Car's not got one so I have nowt to compare to!
Can you measure the well?
Might be able to find one suitable from the dimensions?
Mike
Should be an 077.
Here you go:
http://performancebatteries.co.uk/battery_information
Pick the AH that you want 35 - 40 ish. Then then pick the right connection type (key at the bottom) and size once you have messured the gap and bob is
your uncle and so on
O
[Edited on 26/8/09 by Omni]
077 is correct, it's the same battery used in the pickup, van and very early (1959-1960) positive earth saloons.
If you are playing with older minis the original workshop manual is
online!
I used to fit a heavy duty battery to my Minis which was actually smaller than the standard one.
