Totally off topic, but I just fitted one of these last night after getting a very steep bill through the post as it turn out the meter reading guy has
infact just been estimating how much we’ve been using rather than bothering to open the meter box.
Setting up is simply clipping a white clamp over the red or brown cable that feeds to the fuse box and pressing a button. Range for the display unit
is huge and basically anywhere in the house.
It will display KW’s, Co2 and most importantly £’s based on programmable tariffs
Bit of an eye opener especially for missy who has been running the tumble dryer and washing machine endlessly, 4 full washes a week for 2 people?!
Already the heating has been turned down and lights are being switched off as has the water heater temperature been reduced.
I bought mine from Tesco for £37 a price which I thought 6 months ago was a bit much, ha there’s a laugh
should have got it years ago
Great if you have kids/teenagers or women who don’t appreciate how much a KW is
review linky
[Edited on 3/12/09 by Mr Whippy]
how much does it cost to run?
Originally posted by dinosaurjuice
how much does it cost to run?![]()
errr, forgive me is I am getting confused but 37 quid to tell you the bleedin' obvious???
whatever next, a water meter to tell you when your taps are running?
read it here
that is £ 50 you owe me for my consultance fees
You get them free from British gas, also there has been an agreement made now with the enrgy companies to free issue one to every household.
I've not fitted mine yet though.
Its quite simple really... buy an old house with crap electrics so the lighting system doesnt work..See Here.. and hey presto.. instant energy saving... (however the cost of driving to hospital with all sorts of darkness related incidents are not good)
I got one of
thes
e a few months ago, cost about 8 quid.
Very handy for seeing what draws how much electrickery.
Also, a saving of about £30, which is what? 200kwh?
Originally posted by 02GF74
errr, forgive me is I am getting confused but 37 quid to tell you the bleedin' obvious???![]()
whatever next, a water meter to tell you when your taps are running?![]()
read it here
that is £ 50 you owe me for my consultance fees![]()
I'm not with British gas
I'm also now having to sell my motor bike to pay for this bill, its that high
Yeah I have a good idea how much things cost to run but other people tend to not think about this and it takes a display with a pound sign on it to
make them change their habbits
Upon your recommendation I just purchased one myself. Managed to get the USB dongle aswell for an extra £2 through the OWL website. Looks like a great piece of kit.
OK for leccy, but my heating and hot water are gas...
A couple of years ago I got fed up chasing everyone to turn all the lights off - Since most are on all the time, I changed them all to low energy
bulbs, then changed back the most inconvenient ones after a couple of weeks(the low energy bulbs take a couple of seconds to get going, so we have a
normal bulb in the hall by the front door etc). The result was a 20% drop in annual electricity use(About £200 for us) for about £70 spent on bulbs.
The family all moaned at first because they didn't get instant light, but got used to them after a few weeks. By the way, dont't fall for
the 'as bright as a normal bulb of 5 or 6 times the power use' - I recon if you use 4 times it works out about right (so change 100w bulbs
for 27w, 60w for 15w etc).
Changed the condensor tumble drier for a vented one and got almost the same saving again!
British gas always estimate my readings - it seems they estimate based on the highest equivalent quarters electricity use in the last 10 years,
because they are always 40% more than the actual reading!
Regards
Hugh
A Low energy Bulb is ok but it is basically a prettry strip light. Very inefficient for a couple of minutes untill it wams up.
Did you now the policy of switching off strip lights in offices to save electricity is horse ****. A strip light uses very littel energy to run but a
bucketload to switch on!.. so leave in ON!
[Edited on 3/1212/09 by mad4x4]
Its all fairly simple really.
Light costs next to nothing, unless you are running 6 x 1000watt Sodium Lamps to keep your pot plants warm!.
Average light bulbs are 60 or 100 watts (Thats 10 or more lightbulbs per Kilowatt) and cost very very little to run.
ANYTHING that involves HEAT, will cost you real money to run.
Average kettle is 2.2kw (2200 watts or 22 x 100w lightbulbs per hour). Now you know why it better to only boil what you need at the time!
Your tumble drier, Washer, Oven, Grill (assuming they are not Gas powered) will cost a LOT to run.
My Oven is 10,200 Watts or 10.2Kw
Thats 102 x 100watt lightbulbs worth per hour!
Now consider the Sunday roast, Err thats 20 mins per pound weight + 20 mins.
So a 5Lb lump of Beef is cooked for 120 Mins, or 2 Hours. (in a 10.2kw Oven)
Ask the wife how lonk the Xmas Turkey is going to take to cook? (Try not to look amazed at the cost
Thats 20Khw or 20 units of electricity just to cook the roast beef.
Now you see where the real energy costs are coming from. Thats the equivalent of e LOT of lightbulbs!
Check the manufacturers plate on the back of the machines, this will tell you what the consumption is, and you can work out the cost with a piece of
paper and a pen!
Kilowatts x hours x pence per unit.
You will soon see that anything using HEAT will cost a lot of money, and lights cost next to nothing, especially of they are the energy saving ones,
(usally 10-20watts each).
You dont need an expensive device to work this out. A simple calculator will cost less than a fiver, and can still be used for all those calculations
in the garage during the kit build!
estimated bills are very common, so high this time, but when its read properly, it'll be very cheap. don't sell your bike yet
I prefer the element of surprise and the feeling of anticipation after the meter man has been till the bill comes. We have low energy bulbs throughout but before that the cost of running bulbs was only about 3% of the total bill. When it gets cold we tend to put another jumper on.
hope they
sack him
Mr W, Try pleading poverty and ask if you can split the bil to catch up over (say) 12 months. They can only say no!
Regards
Hugh
think 2k and you almost there, no I'm not kidding either. 4 years of made up estimates with it turns out no actual meter readingshope they sack him
Yep we have just taled about this in the office after i was talking about it being on the news the other morning.
How does supplying, fitting and powering a device that tells you what you should already know help lower CO2?
They were talking about its going to cost the energy suppliers 9 million (or billion i cant remember) to impliment it into every home by 20XX, which
really means you and i are going to pay for it + some profit all so the goverment can say they have helped the world out!
I really dont get it, one thing that made me laugh is they where saying that people think it was a good idea and one couple had saved money from not
leaving both their computers on all night!!!!!! who leaves their computers on all night if they arnt filesharing and TWO in one house.
If youre stupid enough to not know when you are using electricity needlessly then your punishment is paying a higher bill. Dont take it out on all of
us.
grrrr
i have one of thoses, it sits above the fire place i full view, i've knocked about £10 per month off my bill as you can see in real time what you
are wasting....
and mine came from tesco for £35 ish
Ask the wife how lonk the Xmas Turkey is going to take to cook? (Try not to look amazed at the cost)
Check the manufacturers plate on the back of the machines, this will tell you what the consumption is, and you can work out the cost with a piece of paper and a pen!
You will soon see that anything using HEAT will cost a lot of money, and lights cost next to nothing, especially of they are the energy saving ones, (usally 10-20watts each).
You dont need an expensive device to work this out. A simple calculator will cost less than a fiver, and can still be used for all those calculations in the garage during the kit build!
Kick up a fuss about it and if necessary contact the regulator, there is a good chance they'll write off a fair bit of it then as it's their fault. When we got married and my wife left her flat, the final bill was £250 'cos they'd messed up their billing system and not taken any money for the previous 12 months. She complained and they reduced it to £80. She paid the £80 and then was chased for £72 (someone keyed in the wrong figure when they recorded the cheque), when she pointed this out they sent her a £30 bunch of flowers!
I have learnt very early as a student that estimated bills are hugely over estimated! Whenever I get a bill I check there numbers against mine on the meter, usually they are always over, give them a call, give them the correct reading and get another bill with the revised about which is always reduced from the previous bill.
i think mr W is saying that they have UNDER estimated for 4 years, and now they have taken a reading they want a lot of wonga from him.
I thought they had a legal obligation to take a real reading every year?
Did you now the policy of switching off strip lights in offices to save electricity is horse ****. A strip light uses very littel energy to run but a bucketload to switch on!.. so leave in ON!
Mines 15 amp errr, errr, 15 * 240v = 3600w. The oven has a something like 500 degree option to basically cremate all the grease in it - hence the need
for the large amp power supply.
Only problem is it locks the door when its that hot and will only let it be opened once its below 250 degrees otherwise i'd be using it for
flywheel ring gears and the like.
Really? Is it a walk in oven? Mine is rated at 2000 W or 2kW. Remember that it will be on for 10 minutes to warm up then will switch on and off to maintain temperature. Average power is quite a bit less.
Here is an interesting website which shows actual measured consumption figures for various appliances. It shows that an electric oven uses approximately 2kWh over the 2 hours required for the Sunday roast. Mine has a 20 Amp fuse so I guess it is about 10A max or 2400w. Certainly nothing like 10.2kW!
On the other hand, a single 100W bulb running for 8 hours per night, 7 days per week will consume 5.6kWh over the week. Even a 40W table lamp would consume 2.24kWh over the week and there could easily be several of these (or equivalent) through the house.
Efficient lighting will save you much more on energy costs than eating raw food and will probably save you from food poisoning at the same time!
Craig.
i fitted a 14kW oven a few weeks back (110cm all electric range), however as said, thats a total rating, not for an individual cavity with a roast in
it.
I think my largest home energy demand is the heating and gas fire. I have a hot shower in bursts (turning it off whilst soaping etc) so it runs for
about 2 mins all in, which will be fairly cheap. Certainly better than the wife's bath!
Did anyone watch the "Bang goes the theory" program tonight on BBC1? They were doing an experiment where they powered a "typical"
family home using nothing but cyclists, all 80 of them!
According to this program, the biggest villain of energy consumption was indeed the filament light bulb and to demonstrate this, they cooked a chicken
(properly) in an insulated box using just two 60W bulbs for 90 minutes. They said that 90% of the power is returned as heat.
Interesting program, worth a look on iPlayer if you have a spare hour.
I suppose the key is the insulation, cooking is just maintaining a raised temperature, so if you can stop any heat escaping, you can get things cooked very cheaply.
According to this program, the biggest villain of energy consumption was indeed the filament light bulb and to demonstrate this, they cooked a chicken (properly) in an insulated box using just two 60W bulbs for 90 minutes. They said that 90% of the power is returned as heat.
It's worse than 90%, tungsten filament lamps are very inefficient, a 60W lamp converts just over 2% of the electricity into light.
That said I simply don't believe you can properly cook a chicken in 90 minutes with a 120W heater, no matter how much insulation you use.
[Edited on 3/12/09 by MikeRJ]
Originally posted by iank
Personally I hate the things as they are so dim for a few minutes after switch on and I can see some flicker if I see them out of the corner of an eye.
Re the heating aspect of old style lights - I read somewhere that installing low energy bulbs doesn't save as much energy as you might think because you have to turn up the heating a notch to compensate for the loss of heat output from the filament bulbs.
I used to believe that, but recently found (along with the maths to demonstrate) that it's an urban myth that's been around since the 70's.
They do take a lot more current (inrush) when they are starting, but it's only around 5-10seconds worth of running time if you work it out. So if you're leaving the room for a few minutes turning them off saves some money. Personally I hate the things as they are so dim for a few minutes after switch on and I can see some flicker if I see them out of the corner of an eye.
Big companies leave them on mainly to allow the cctv security cameras to work, and lets the security guards to wander about without inconvenience.
http://www.bbc.co.uk/iplayer/episode/b00p8469/Bang_Goes_the_Theory_The_Human_Power_Station/
