ODB 2 Fault codes Help
m8kwr - 10/12/09 at 09:23 PM
I had a cable from ebay, run it on the car, skoda fabia, and i have found a fault code in the steering assist, the code is, does anyone know where i am able to find some more information about what is wrong, i think it is the steering sensor, don't want to buy one and it not be that...
Control Module Part Number: 6Q0 423 156 Q
Component and/or Version: LenkhilfeTRW V250
Software Coding: 00140
Work Shop Code: WSC 13765
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
79-00 - Please Check Fault Codes
Many thanks
boggle - 10/12/09 at 09:35 PM
hi there..
u2u me with the vehicle year and what engine as i have fault codes list in my auto data software
boggle
m8kwr - 10/12/09 at 09:38 PM
Thanks, U2U sent
britishtrident - 10/12/09 at 09:41 PM
First rule of fault code reading is fault codes can't be trusted, they rarely point to the true cause of a fault and are often spurious.
Second rule is take a note of the codes then clear them and see if they re-occur.
I have gut a feeling this is either spurious fault code or one of those mysterious codes that occur when a a brake light switch goes bad (strange but true).
Clear it if the code re-occurs you might have a fault but if you have no symptoms don't worry too much.
Also VAG-Com isn't perfect as most of the codes were done by reverse engineering and VAG use a lot of different ECUs.
Not directly connected to your problem but something to be aware of
http://www.gendan.co.uk/article_12.html
boggle - 10/12/09 at 09:41 PM
matt_gsxr - 11/12/09 at 10:36 AM
googling your error code shows up loads of stuff.
None of it very informative.
Sounds like a catch all error for "I don't understand".
Matt
