Guys,
A friend of mine has an Escort TD, I think it's the mk5 or maybe mk4, I've attached a couple of pics of cars that look like it. Yesterday
she told me she's had situations where the car brakes' wouldn't perform. That's in sections of the road where there is high slope
downhill (a pass for instance) so I got the impression that she's not using the brakes nor the gears properly resulting in overheating. Apart
from the obvious training to correct this, would you recommend fitting different pads, like the Green Stuff ones I have in the Locost? (Also do they
fit?) I'm scared that she may bend her discs due to overheating.
Image deleted by owner
BTW, is that car FWD or RWD? She also mentioned something about handling so I'm curious.
Alex
if the brakes are in reasonable condition they should work ok unless they are being overheated as you state,other thing to look at is the vacume pump
on them,they are known to give up or not work too well
I had a guy ask me about his brakes not working a while ago - mainly in the wet or in icy conditions on his farm track.
Turned out it was his ABS cutting in as his front wheels tried to lock up! DOH!
Thats a Mk6. FWD.
Adam
[Edited on 29/7/04 by phelpsa]
The brakes were brilliant and never faded. I fitted new Brembo discs and ferodo road pads and never had any trouble in the 2 years before I got rid. I'd go with Conrod on the vacuum pump theory if all the other bits are o.k. and the fluids fresh.
Thanks everyone!
I'll see if the car has ABS first, then I'll test the brakes to see how they feel and will have that vacuum pump checked if need be.
Pete BTW, did you fit Brembos as an UPGRADE or was it just a replacement due to wear out of the original ones? Did you fit bigger discs?
Alex
Standard vented discs, just that they are made by Brembo. Some cheapo ones are not as vented or well machined I've noticed
if its anything like the roads on your spanish islands, riding the brakes on a long downhill section isnt gonna make em work well..... is she using
engine braking on long downhill bits?
My wife had a fiesta once that had crap brakes - it was the disks. They were literally 'chunking off' the brake surface, reducing the amount
of braked area.
Is the brake fluid ok? needs flushing / bleeding?
atb
steve
Originally posted by theconrodkid
...other thing to look at is the vacume pump on them...
It's an abbreviation for turbo diesel Dick.
Thanks Pete - I missed that!!
(Short-sighted old git).
