digital tv recording
matty h - 2/8/11 at 07:24 PM
Can you connect a vcr to a digital tv to enable me to record digital tv or do I need a digital recorder.
Thank Matty
Worzey - 2/8/11 at 07:31 PM
In theory you should be able to record to a VCR but it will be an analogue signal out via a scart cable (I assume). This means it will be analogue when you play it back so lower quality and definitely not HD.
matty h - 2/8/11 at 08:06 PM
I have currently got it set up to record analogue tv but with the analgue signal been turned off, I want to record the digital tv.
Matty
Worzey - 2/8/11 at 09:25 PM
Right, so you'll need some type of analogue output from the Digital TV (or set top box) to feed the input on the VCR. I guess this will depend on what TV/set top box you have and the outputs it supports.
I assume on the old system you feed the ariel input into the VCR then chained to the TV via a scart lead?. You'll to do it from the digital receiver back to the VCR this time round for it to work correctly.
Ninehigh - 3/8/11 at 07:45 AM
Yeah it'll be:
Ariel>digital box>vcr>tv
You'll only be able to record "what you're watching" though.
I remember one of my mum's friends would record things off sky for us and we'd have to flick through her messing about with the menus
