Just thought id mention that the code hob15 gets 15% off hobs at comets. There are other codes too for ovens etc, i'll try to remember. Seen the
hob i wanted at £360 on my usual supplier, comet have it for £212 after disconut, and you can still pick it up at your convinience.
Absolutely no use unless you are after household appliances though
Don't forget another 2.5% using TopCashBack
also, if you mention "pricewatch", and say the cheapest you have found was on there website, you can save loads
i did it, and on a £639 lg Tv , and i paid £439
and the Assistant just took my word !!
Originally posted by Snuggs
Don't forget another 2.5% using TopCashBack![]()
If hob15 gets you 15% off did you try putting hob100 in just in case?
