Yes, I need some pulleys. Strong and cheap, sized for 6-8mm rope with a diameter around 30-50mm. Any suggestion considered.
I've had a bit of a look and found a few climbing pulleys that are getting there, or industrial blocks and sheaves that would do it if i wanted
100, and sailing kit thats extra ordinarally expensive but nothing quite there yet.
Its for the steering of a narrowboat with wheel steering, where I'm planning to use high 6mm dia performance dyneema rope as a compromise between
strength and compactness, as a similar strength steel cable has a much large bend radius and without a lot of work I'm limited to getting it fit
in the space of the old system, which used 3mm stainless steel and nylon pulleys, which wasn't up to the job long term.
I need three singles and two doubles (or 7 singles) total budget around £100.
*edit for late night spelling
Daniel
[Edited on 19/4/2012 by dhutch]
Our very own Flak Monkey does pulleys for people. Worth a message to him I'd have thought.
Don't see why you can't just use normal marine pulleys.. ironically they're even intended for boats!
BRAND NEW Barton size 3 Reverse shackle block / pulley | eBay
7 of those doesn't break your budget? 45mm diameter up to 10mm rope?
Originally posted by PSpirine
Don't see why you can't just use normal marine pulleys.. ironically they're even intended for boats!![]()
If you have more than one pulley isn't the load shared amongst them ?
