Hi All
Call to all Iveco drivers or anybody who knows about Ivecos.....
Had a dash warning light appear on dash board, which has come on in the past briefly then went off again, but this time round it has stayed on
permanently and i do not have a Iveco handbook to track its meaning down, nor has the internet thrown up any joy.
Pic below of light: Imagine a red background to the WHOLE thing but the lines you see are in white.
Any thoughts?
ta
Coolant level or fan fault?
From a little investigation it would apper to mean low coolant level. Don't take that as gospel though as ony had a quick search. The fact it was
intermittent but is now permanent would suggest a slow coolant leak, equally though it could be a frayed wire on the sensor.
Rich
Ah yes....low coolant! Would make sense if the coolant was low i guess, but it is full. Think i will need to look at the wiring in that case. I
shall go investigate.
Thinking about it i am pretty sure it is likely to be a dodgy connection coz on the way home from Cadwell on sunday went over a large pothole, the
whole van shuddered alot and next thing i saw was brake fluid low warning light come on. Fluid levels right up....jiggle of the connectors and the
light went off. Hey presto!
It is an oldish van....and an Iveco at that. To be be expected i guess (failing connectors)!
