OT: plumbing question
dan8400 - 30/7/12 at 08:28 PM
My hot water pressure is crap (took 18 seconds to fill a 1 litre jug). I have a hot water cylinder feed by cold water header tank. I could put the tank into the roof to help the head height above the taps. The loft hatch, however, is tiny. I would have to bash a hole in the ceiling to get the cold tank up there.
So, my question is, can I feed the copper cylinder from the mains pressure cold water instead of major work to get the tank up high?
I know I could fit a pump but this would involve an electrician etc and more cost
Any advice appreciated
Dan
JoelP - 30/7/12 at 08:36 PM
NO!
And i mean hell no!
Could you not find a small header tank that would fit through your loft hatch? Volume isnt too important.
Or get a combi boiler fitted.
[Edited on 30/7/12 by JoelP]
dan8400 - 30/7/12 at 08:42 PM
Excuse my ignorance. But why not? Obviously I wont do it if you say not to. But I am curious as to what might happen?
Dan
mookaloid - 30/7/12 at 08:43 PM
could be quite spectacular
Wadders - 30/7/12 at 08:44 PM
Uprating the cold feed from 22 to 28 between tank and cylinder will help, also check you don't have a partial blockage
while you're at it. If all else fails, providing you have decent incoming mains pressure fit an unvented cylinder and bin the feed tank.
Al.
JoelP - 30/7/12 at 08:50 PM
A normal hot tank cannot take the pressure, it would burst and spray hot water everywhere. Al's suggestion of an unvented tank is one option, i guess you need to weigh up costs etc.
Wadders - 30/7/12 at 08:56 PM
Just remembered, Polytank used to do "coffin tanks" specifically designed to fit through small loft hatches
you can also link two tanks together to get the required volume. If no pumped showers are involved and assuming
a regular sized 117 litre cylinder, you will need a minimum of 25 gallons in the loft. Approx 125 litres.
Al.
dan8400 - 30/7/12 at 09:01 PM
Can I fit some kind of on demand pump. In-line. After the cylinder?
dan8400 - 30/7/12 at 09:02 PM
Al.
no power showers or pumps fitted in the system. The shower is fed from cold - mains only
tegwin - 30/7/12 at 09:28 PM
You could fit a pump after the hot water tank... you would need a hot and cold feed at the same pressure (so hot from cylinder, cold from header tank).... Pumps are noisy though!
If you can, I would look at getting a few small tanks up as high as you can in the loft and join them together. (that being the cheapest option)
If you do go down the route of fitting a pump to help with showers you need to be really really careful how the pipework is laid out to avoid getting air in the pump.
dan8400 - 30/7/12 at 09:30 PM
I don't need to pump hot water for the shower. I just need to increase water pressure to the taps
paulf - 30/7/12 at 09:42 PM
I bought a Stuart turner 3 bar pump for this exact purpose a couple of years ago and never fitted it , it has a flow sensor that turns it on automatically when water flow is detected .It is complete with flexi hoses to connect into the system with and then just requires wiring into a 13 amp supply via an RCD.
If you decide to fit a pump then let me know as i need to get rid of it and would sell it at a good price.
Paul
907 - 30/7/12 at 09:48 PM
Quote: The loft hatch, however, is tiny.
Out of interest, what size is "tiny"?
I presume it's big enough to climb through.
Paul G
Macbeast - 30/7/12 at 09:57 PM
It wpuld seem the simplest solution would be to bash a hole in the ceiling. Why complicate matters with pumps etc ?
Wadders - 30/7/12 at 10:03 PM
Agree, fitting a pump is attacking the problem from the wrong end, and will most likely lead to other problems
cavitation, and mismatched outlet pressures etc.
By the time you have laid out for a pump and a warix flange, and a sparky to fit a fused spur/RCD you might as well just do the job properly.
Nothing wrong with gravity if it's done right.
Al.
]Originally posted by Macbeast
dan8400 - 31/7/12 at 06:51 AM
Paul G
About 14" x 20"
dan8400 - 31/7/12 at 06:53 AM
Paul
Sounds good Paul
How much are you looking for? I have placed a bid on ebay on a pump. Not guaranteed to win it.
Dan
Slimy38 - 31/7/12 at 07:07 AM
I know it's the most expensive option, but I'd actually look at fitting the aforementioned combi boiler. In fact, the plumbers on here might be able to confirm it but with a combi boiler running costs being lower than the traditional copper kettle, you might actually break even after a few years?
